Fix Common Problems Errors and Warnings and poor VM performance
Fix Common problem is reporting:
Error: Call traces found on server.
Warning: irq 16: nobody cared found on your server
I recently upgraded to version 6.3.5 and now my Windows VM stutters and is unusable. It worked nearly flawlessly for all previous unraid versions. All of these issues showed up immediately after upgrading.
M/B: Gigabyte Technology Co., Ltd. - Z170-HD3-CF
CPU: Intel® Core™ i7-6700K CPU @ 4.00GHz
HVM: Enabled
IOMMU: Enabled
Cache: 128 kB, 1024 kB, 8192 kB
Memory: 32 GB (max. installable capacity 64 GB)
Network: bond0: fault-tolerance (active-backup), mtu 1500
 eth0: 1000 Mb/s, full duplex, mtu 1500
Kernel: Linux 4.9.30-unRAID x86_64
OpenSSL: 1.0.2k
tower-diagnostics-20170628-1951.zip
IRQ is getting disabled, look for a bios update or try v6.4rc, different kernel may fix your problem.
Unfortunately there was no BIOS update available. I've upgraded to the latest 6.4.0-rc6 and I am still getting the same errors. I've attached my latest diagnostics information.
tower-diagnostics-20170629-2151.zip
