July 5, 20179 yr I created a new VM, it looks like this: It installed fine, I have CentOS 7 + cPanel running on it. It is running on my cache SSD so it boots up super quick. The problem starts when I logged on it from SSH. I get error messages like this every second: [root@mrlb1b myscripts]# Message from syslogd@mrlb1b at Jul 5 15:11:32 ... kernel:Uhhuh. NMI received for unknown reason 21 on CPU 0. Message from syslogd@mrlb1b at Jul 5 15:11:32 ... kernel:Do you have a strange power saving mode enabled? Message from syslogd@mrlb1b at Jul 5 15:11:32 ... kernel:Dazed and confused, but trying to continue Message from syslogd@mrlb1b at Jul 5 15:12:02 ... kernel:Uhhuh. NMI received for unknown reason 31 on CPU 0. Message from syslogd@mrlb1b at Jul 5 15:12:02 ... kernel:Do you have a strange power saving mode enabled? Message from syslogd@mrlb1b at Jul 5 15:12:02 ... kernel:Dazed and confused, but trying to continue Message from syslogd@mrlb1b at Jul 5 15:12:32 ... kernel:Uhhuh. NMI received for unknown reason 21 on CPU 0. Message from syslogd@mrlb1b at Jul 5 15:12:32 ... kernel:Do you have a strange power saving mode enabled? Message from syslogd@mrlb1b at Jul 5 15:12:32 ... kernel:Dazed and confused, but trying to continue Message from syslogd@mrlb1b at Jul 5 15:13:02 ... kernel:Uhhuh. NMI received for unknown reason 31 on CPU 0. Message from syslogd@mrlb1b at Jul 5 15:13:02 ... kernel:Do you have a strange power saving mode enabled? So I searched around and this post points out that changing CPU Mode from Host Passthrough to QEMU Emulated solved the problem: https://forums.lime-technology.com/topic/46550-debian-84-vm-uhhuh-nmi-received-for-unknown-reason-20-on-cpu/?do=findComment&comment=551532 The problem now is, after changed the CPU mode to QEMU Emulated, the VM won't fully boot anymore. It's been 1 hour and the VM is stuck on this screen: I can't SSH into it. If I change CPU Mode to Host-Passthrough it boots up fine again, but I get those kernel errors every second again. Has anyone seen this before? Any help is appreciated.
July 6, 20179 yr Author I have installed a new VM, using QEMU64 CPU Mode from the start, and it ended up having the same problem. I've also tried assigning CPU0 to the VM. Neither worked. Any suggestions?
July 31, 20179 yr I had this problem also this fixed it for me i edited the file /etc/default/grub i just added pcie_aspm=off i still couldnt use cpu host pass-through because i still got the same errors but i switched it too QEMU64 and it has been a couple of hours now and i haven't had the error popup yet. GRUB_TIMEOUT=5 GRUB_DISTRIBUTOR="$(sed 's, release .*$,,g' /etc/system-release)" GRUB_DEFAULT=saved GRUB_DISABLE_SUBMENU=true GRUB_TERMINAL_OUTPUT="console" GRUB_CMDLINE_LINUX="crashkernel=auto rhgb quiet pcie_aspm=off" GRUB_DISABLE_RECOVERY="true" after editing the grub file run this command grub2-mkconfig -o /boot/grub2/grub.cfg and reboot. see if it works for you it did for me.
