July 19, 20179 yr Over the past few months, Fix Common Problems has been indicating that 'Machine Check Events detected on your server'. After procrastinating for a while, I recently had some broader network issues that scared the crap outta me and put me into maintenance / tune -up mode to avoid any other major issues. Thus I'm here with the log from MCE. I am currently running unraid 6.3.5. Log is attached. If anyone can provide some help, it would be greatly appreciated! Thanks!! mcelog-148-x86_64-1.txz
July 24, 20179 yr Author Can anyone assist with this issue? If I'm missing any info, or if I'm posting in the wrong place, please let me know. Thanks!!
July 24, 20179 yr That's not the mce log. Rather, that's the installation files for the program itself. If you run another scan with Fix Common Problems, and if it tells your that there is still an mce, then post the diagnostics (assuming of course that you installed mce log via nerdpack and didn't just simply download it by yourself)
