July 25, 20179 yr Hello I'd like to have a 10GB connection between my unRAID and VMware server. I'm using a HP 1810G-24 ProCurve as my switch and had a peek on Mellanox ConnectX-2 (MNPA10-XT) for both servers. Should I make a direct connection between my two servers and if so how do I set that up? If I should connect both via switch how do I check if my router works with these cards? Thanks
July 26, 20179 yr Your HP1810-24G does not support 10G connections via its SFP Slots. If you were to do a back-to-back link between your ESXi Host and the UnRaid server, you would need to put it on a separate subnet to ensure that the routing isn't affected. Using the Mellanox cards should be straight forward, especially from the VMWare end, you'll just need to setup a new VMKernel port on the new subnetWhen you do the subnet on the two servers, try to avoid putting in a default gateway as this can impact the routing table significantly Sent from my iPhone using Tapatalk
