August 1, 20178 yr 2017-08-01T04:46:38.003885Z qemu-system-x86_64: -device vfio-pci,host=04:00.0,id=hostdev2,bus=pci.0,addr=0x6: Failed to mmap 0000:04:00.0 BAR 2. Performance may be slow is the warning received regardless of which VM I start. The USB card is in its own IOMMU group: IOMMU group 17 [1b73:1100] 04:00.0 USB controller: Fresco Logic FL1100 USB 3.0 Host Controller (rev 1 Here is what I have in the config file: append pcie_acs_override=downstream pci-stub.ids=1b73:1100 pci=realloc=off isolcpus=2,3,6,7 initrd=/bzroot Not sure if it helps but I had to use acs override to get unraid to recognise both gpus 260x & 480 pci=realloc=off had to be added to get the supermicro 8 port sas card to behave itself I have tried removing pci=realloc=off but it made no difference, the warning remains Edited August 1, 20178 yr by Guest
