August 22, 20178 yr Hi Everyone, This one is a bit weird - After my unRAID box is up for a couple of days I get poor writing speeds. -Reading form the array is full 1gbit speed. -Writing to the array drops from 1gbit to 20mbit and below. -Problem extends further than Samba. My VM doing a speedtest (fast.com) will drop from 100mbit to 20mbit. -Restarting unraid or unplugging/replugging the lan cable resolves the issue, but it does appear again in a couple of days. Not sure where to go from here, any advise as to here to look would be appreciated. Cheers, Kris
August 23, 20178 yr Attach diagnostics zip file taken from a fresh boot, and after the problem starts happening.
August 23, 20178 yr Author Here is diagnostics of it in FAULT STATE. I'll get the fresh boot logs later, at this stage I would like to leave it in fault state to try to trouble shoot it. unraid-diagnostics-20170823-1016.zip
August 23, 20178 yr Author Looking at the diagnostics (System - ethtool in particular) I found that 1) I still had bonding enabled from a previous setup (now back to a single NIC) 2) The link speed had been reduced to 10Mbit. Settings for bond0: Speed: 10Mb/s Settings for eth0: Speed: 10Mb/s I turned the bonding off and the network stack restarting returned it to speed: 1000Mb/s This may resolve my issue.
