***GUIDE*** How to passthrough Intel chipset audio
so there is some voodoo
I rebooted
I logged into Server 2016 and audio option gone
I tried to start Win10vm  wasn't able to said a conflict
I stopped Server 2016  and was able to start Win10VM and the audio I showed is there
neither xml shows  the thing..  im thinking the true XML file hase that added stuff I added... but GUI doesn't display it all
either way here is the error I get
damn this voodoo lol
  • Replies 119
  • Views 61.7k
  • Hi @CiaoCiao   Replace this line of your syslinux :  append vfo-pci.ids=1912:0014 initrd=/bzroot   with this one : append vfio-pci.ids=YOURDEVICEADDRESS modprobe.blacklist=i2
  • Hey, that just did the trick!   Thanks a lot @matthope!   I'm running a very light setup right now, with just a G4560 on a Z170 Pro Gaming AC motherboard, 8GB of RAM and a USB 3.0 exten
  • The instructions here got mine working.  Thank you @matthope
ah ok  and form view xml view  I set it to  xml view
that's how I edited it
but maybe you mean FormView overwrites XML Edit
either way Server 2016 lost its audio  but the Win 10 was able to keep it .. so I going to test least on the windows 10  but was hoping ti stay on win2016
actually how do I fix this now lol
to get windows 2016 server and windows 10vm to run same time
how do I remove the audio  from the windows 2016  since I get that error now I cant really test lol ugh
I rebooted
You can only use the audio device with 1 VM at the time. The configuration seems to be working. Also, when playing with embedded motherboard device, sometimes it require to remove the power completely (remove the AC Plug).
Exactly, Form View overwrite XML edit.
If you want to run both of them at the same time, you need the remove the audio card in one of the XML.
well I wanted to run it on windows 2016 server
ok I guess that's a glitch  FormView overwrites XML view when you don't do anything
and I cant edit the XML  remember I mentioned
when in XML view mode I edited it  what you told me to add...  Click Save  and ran VMs and they worked
but the XML view when you go back that input is gone
I just tried reputting in and I get duplicated error..  so I cant even remove it..
its like XML View knows that input is there but wont show it.. or let me remove it or anything
so now im stuck cant remove it
  <devices>
      <driver name='vfio'/>
      <source>
        <address domain='0x0000' bus='0x00' slot='0x1f' function='0x3'/>
      </source>
      <alias name='hostdev1'/>
    </hostdev>
First of all it is very weird that thoses XML doesn't appears. However, if you edit something with the form view (try changing the USB setting) and save it. This will overwrite any XML modification. This should reset the XML to the base configuration. You should also try to do a power cycle after this modification. (remove the power plug)
nope its fk'd now lol frig
so  shut down  pulled the plug
started it back up Win2016 starts  and then I tried to start win10  nope  so I went into edit and chckeed off to use USB APC  and click save
and re tried to run VMwin10  nope still duplicate it saying
so now I cnat run both lol and it is saving it somewhere   ill repost the xml    as I just rebooted
Windows 10VM
<domain type='kvm'>
  <name>Windows 10</name>
  <uuid>d720775d-2509-7680-4980-0e8f218a5283</uuid>
  <metadata>
  </metadata>
  <memory unit='KiB'>2097152</memory>
  <currentMemory unit='KiB'>2097152</currentMemory>
  <memoryBacking>
    <nosharepages/>
  </memoryBacking>
  <vcpu placement='static'>8</vcpu>
  <cputune>
    <vcpupin vcpu='0' cpuset='0'/>
    <vcpupin vcpu='1' cpuset='4'/>
    <vcpupin vcpu='2' cpuset='1'/>
    <vcpupin vcpu='3' cpuset='5'/>
    <vcpupin vcpu='4' cpuset='2'/>
    <vcpupin vcpu='5' cpuset='6'/>
    <vcpupin vcpu='6' cpuset='3'/>
    <vcpupin vcpu='7' cpuset='7'/>
  </cputune>
  <os>
    <type arch='x86_64' machine='pc-i440fx-2.11'>hvm</type>
    <nvram>/etc/libvirt/qemu/nvram/d720775d-2509-7680-4980-0e8f218a5283_VARS-pure-efi.fd</nvram>
  </os>
  <features>
    <acpi/>
    <apic/>
    <hyperv>
      <relaxed state='on'/>
      <vapic state='on'/>
    </hyperv>
  </features>
  <cpu mode='host-passthrough' check='none'>
    <topology sockets='1' cores='4' threads='2'/>
  </cpu>
  <clock offset='localtime'>
  </clock>
  <on_crash>restart</on_crash>
  <devices>
      <source file='/mnt/user/domains/Windows 10/vdisk1.img'/>
      <boot order='1'/>
    </disk>
      <source file='/mnt/user/isos/Windows10 ISO.iso'/>
      <target dev='hda' bus='ide'/>
      <readonly/>
      <boot order='2'/>
    </disk>
      <source file='/mnt/user/isos/virtio-win-0.1.141-1.iso'/>
      <target dev='hdb' bus='ide'/>
      <readonly/>
    </disk>
    </controller>
      <master startport='0'/>
    </controller>
      <master startport='2'/>
    </controller>
      <master startport='4'/>
    </controller>
    </controller>
    </controller>
    <interface type='bridge'>
      <mac address='52:54:00:26:c6:79'/>
      <source bridge='br0'/>
      <model type='virtio'/>
    </interface>
    <serial type='pty'>
        <model name='isa-serial'/>
      </target>
    </serial>
    <console type='pty'>
    </console>
    <channel type='unix'>
    </channel>
    </input>
    <graphics type='vnc' port='-1' autoport='yes' websocket='-1' listen='0.0.0.0' keymap='en-us'>
    </graphics>
    <video>
    </video>
      <source>
        <address domain='0x0000' bus='0x00' slot='0x1b' function='0x0'/>
      </source>
    </hostdev>
    <hostdev mode='subsystem' type='usb' managed='no'>
      <source>
        <vendor id='0x051d'/>
        <product id='0x0002'/>
      </source>
      <address type='usb' bus='0' port='2'/>
    </hostdev>
    <memballoon model='none'/>
  </devices>
</domain>
Windows 2016 Server VM
<domain type='kvm'>
  <name>Windows Server 20162</name>
  <uuid>bbb8584b-4746-d74f-32da-14e482fd89b5</uuid>
  <metadata>
    <vmtemplate xmlns="unraid" name="Windows Server 2016" icon="windows.png" os="windows2016"/>
  </metadata>
  <memory unit='KiB'>4194304</memory>
  <currentMemory unit='KiB'>4194304</currentMemory>
  <memoryBacking>
    <nosharepages/>
  </memoryBacking>
  <vcpu placement='static'>2</vcpu>
  <cputune>
    <vcpupin vcpu='1' cpuset='2'/>
  </cputune>
  <os>
  </os>
  <features>
    <acpi/>
    <apic/>
    <hyperv>
      <vapic state='on'/>
    </hyperv>
  </features>
    <topology sockets='1' cores='1' threads='2'/>
  </cpu>
  </clock>
  <devices>
      <source file='/mnt/user/domains/Windows Server 20162/vdisk1.img'/>
      <boot order='1'/>
    </disk>
      <source file='/mnt/user/isos/SVR2016.ENU.APR2017.iso'/>
      <readonly/>
      <boot order='2'/>
    </disk>
      <readonly/>
    </disk>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
      <mac address='52:54:00:bf:d8:95'/>
    </interface>
    <serial type='pty'>
      </target>
    </serial>
    </console>
    </channel>
    </input>
    </graphics>
    <video>
    </video>
      <source>
      </source>
    </hostdev>
    <memballoon model='virtio'>
    </memballoon>
  </devices>
</domain>
both have that  code you had me enter in  between the <devices></devices> as I add it right afther <devices>  above <emulator>  but you see its not there but the Wins 10 sees it still as the Audio is in there  but Win2016 has lost it.. no audio   yet  both seem to still record it as they both have it  as its conflicting
so its written somewhere else then????  another xml file  or do I re edit the boot file from the orginal setting when you click FLASH under main and edit the append option
I turned off the pci ACS override  going to see if that helps???
4 minutes ago, comet424 said:
Windows 10VM
<domain type='kvm'>
  <metadata>
  </metadata>
  <memoryBacking>
    <nosharepages/>
  </memoryBacking>
  <cputune>
  </cputune>
  <os>
  </os>
  <features>
    <acpi/>
    <apic/>
    <hyperv>
      <vapic state='on'/>
    </hyperv>
  </features>
  </cpu>
  </clock>
  <devices>
      <boot order='1'/>
    </disk>
      <readonly/>
      <boot order='2'/>
    </disk>
      <readonly/>
    </disk>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
    </interface>
    <serial type='pty'>
      </target>
    </serial>
    </console>
    </channel>
    </input>
    </graphics>
    <video>
    </video>
      <source>
      </source>
    </hostdev>
      <source>
      </source>
    </hostdev>
  </devices>
</domain>
<domain type='kvm'>
  <metadata>
  </metadata>
  <memoryBacking>
    <nosharepages/>
  </memoryBacking>
  <cputune>
  </cputune>
  <os>
  </os>
  <features>
    <acpi/>
    <apic/>
    <hyperv>
      <vapic state='on'/>
    </hyperv>
  </features>
  </cpu>
  </clock>
  <devices>
      <boot order='1'/>
    </disk>
      <readonly/>
      <boot order='2'/>
    </disk>
      <readonly/>
    </disk>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
    </controller>
    </interface>
    <serial type='pty'>
      </target>
    </serial>
    </console>
    </channel>
    </input>
    </graphics>
    <video>
    </video>
      <source>
      </source>
    </hostdev>
    </memballoon>
  </devices>
</domain>
The code lines are present, look at the end of the device section. Remove the hostdev completely from one of the VM.
No, don't do that.
ok so ya this is confusing..  1   already turned off the ACS override off.. and seems to be ok with it disabled
Win10VM   doesn't have those lines where did it go????
I edited windows 2016 and removed the lines from the bottom   so I can run both
but this is confusing I tell ya
testing a new windows 10VM install to see what happens
Windows 10 Config : Remove those lines.
You don't need to do anything else.  The XML files doesn't keep the modification exactly where you place them. So look carefully and try to focus on one thing at the time.
ok this messed  lol  I been using the Find In Page search it cant find that stuff..
but maybe that lines supposed to be in there.. remember you had me change it from 06 to 08
why that one 06  that isn't the Audio one then
as I put a 08 for the audio
lol man this stuff boggles the mind... and do you want me to reset the ACS back to downstream it keeps setting it before
nvm  that 06 must be yours.. I looked at mine  it was 08...
I just cant search for it in find in page
What?
Look man, trust me the line that i've show you in the red box, are the line for the audio card.
Edited by matthope
I said the one in your pic with the redbox  is yours because you confused me there as it says Slot 6.. reason I said  I don't have a slot 6
and then when I look on mine it said Slot 8
and I said reason  I couldn't find these..  InterNet Explorer.. Google Chrome.  FIND In Page  can not find the Words that Slot  or hostdev
I removed them from both... and re added to Windows 2016  but doesn't work for it anymore dunno how it worked in the first place..
sorry for you miss understanding me..  hard to explain sometimes when I have dyslexia  it came out fine for me
Edited by comet424
Okay,
1. can you tell me which VM you want to have audio?
2. reactivate pcie override.
3. reboot your system.
4. send your xml configuration again.
5. wait for my reply.
Edited by matthope
id like it to run on windows 2016 as I use it for my Webserver..
the Windows 10vm  was just to play around with etc
and see this is what I ment when I searched it says 0 results yet I see it there...
technology is great when it works
I was testing both  but I cant seem to get it to work on windows 2016
I currently using  Virtio 141 drivers   I currently downloading the Virtio 161 drivers to see if that helps..
my internet  not that good as its taking long time to download the 161
and I re changed vm manager back to "Both" for the acs   but I noticed it goes to downstream after
so ya  id like it to work on Windows 2016 server if possible  I just waiting for the driver to download
Edited by comet424
if there is no way to get the audio to stay in windows 2016  server then that's ok  ill manage to run it in a windows 10vm
I just perfered 1 VM running  I still learning all this
its pretty cool I can run 2 VM and an unraid all on the same computer at the same time
least it worked on the vm win10
and I really appreciate that of you 🙂
Edited by comet424
so on windows 2016  it wouldnt work  only remote audio which was it send the audio through Remote Desktop App
now windows 10  shows it works when i out it to my speakers i hear audio  but it sounds like it ran through a synthesizer
like its scrambled audio
would that be driver issues or because its running through a VM??  as i never had it before when i installed win10 on its own  without unraid
or is there something else i need to add.
least its working to an extent
i downloading audio drivers as its cracklying audio  but since the package is over 400meg and my internet slow  wont be done till tommorow  so ill try again tommorow...
thanks for the help so far
Edited by comet424
so i installed the drivers for audio
but its still has the static audio reverbing kinda sound effect to it..
any other tricks to fix this?
ive changed cables no help either
hey matt is your sound working..  i got it to show up on my win 2016 server but its also staticy screatch sound
is there something else to do
there is another guy having same audio issues with his win 10
do you happen to know what else to do to fix this
First of all, could you please stop spamming the forum? Thanks.
As for your issue i'm not sure what can cause it. However, I have few ideas that could help you.
1. Try changing the machine emulation Q35/i440fx.
2. Try this : https://wiki.unraid.net/UnRAID_6/VM_Guest_Support#Enable_MSI_for_Interrupts_to_Fix_HDMI_Audio_Support
3. Try this :
If all of this doesn't work then sadly, i couldn't help you further.
ok ill try that
but  i wasnt spaming nothing  dont know what your talking about... never sent any spam info
sent you the steps i was doing and going through so i could get trouble shooting help  never once spammed nothing
but thanks  ill try this... thanks for the info
