September 15, 20178 yr I'm having some problem logging into the web interface I have to restart the server for temporary access to the web interface and it was last for 20 seconds then after that it comes up with page cannot be found for some reason it can't find the DNS address is there anything anyone can suggest are a way to help me sort this out Am using Asus rt68u My set-up Motherboard Supermicro MBD-X9SRL-F-O CPU Xeon E5 2670-v2 2.3ghz MEMORY 4 Samsung 8GB M393B1K70DH0 CK0 Cooler Master Hyper 212x SSD SanDisk Plus 240GB 4x Seagate IronWolf 4TB Case Fractal Design Define R5 PSU RMX 850 80+ Gold 5 Fractal Design X2 GP 12
September 15, 20178 yr Community Expert Hook up a monitor and keyboard. See if the server has booted fully. If it has, login into the command line interface as root and the password for root. Then type diagnostics at the command line prompt. That will write the diagnostics file on your flash drive in the logs folder/directory. Attach that file to your next post.
