Help with system IRQ16? CALL TRACE?
New to unraid and been running unraid on a HP Elite 8300 16 gig ram 3 WD red's and WD black 256 NVME drive.
and i have been haveing a issue with a call trace poping up and when i reboot it goes away some time
I uploaded my system log PLEASE PLEASE help. i know its not the mobo since i had 2 system's and i swapped the CPU and ram to another system possible its the cpu
PLEASE PLEASE help
tower-syslog-20170917-1915.zip
IRQ16 was disable, used by a USB device:
Sep 17 19:13:02 Tower kernel: Disabling IRQ #16
Sep 17 19:13:34 Tower kernel: usb 1-1.6: USB disconnect, device number 4
Look for a bios update, but if all is working well you can ignore, if a USB device stops working you may need to use a different USB port/controller.
