September 22, 20178 yr Hi all, I'm new to the forums, and certainly not a literate Linux user. So please be gentle. I have been running Unraid for awhile now and have had pretty great experience with it until recently. Things have been rough on that server of late, I had a power supply slowly die due to a power surge and cause all sorts of weird issues. I swapped out the power supply and install a UPS, the array works, mostly now but not like it used to. and in the words of Hank Hill, "That server just ain't right" anymore. I would appreciate any help you guys can offer. I use Unraid primarily for storage and for Plex, but I have a few other dockers running, mostly low key usage though. The major issues I have been experiencing have been the server not responding to the web gui, or plex failing in mid stream. I have a drive that claims to be either write only or full to capacity , and I just started getting a warning from windows via the unraid GUI, saying that my mapped drive to the array has a corrupted recycle bin. I think those issues are connected, as it appears that I am unable to delete things anymore. Now I getting a warning message from "Fix Common Problems" (which is a great tool btw!) about my log file being giant and I should post the diag here. So I have. Thanks in advance for any help you can send my way! mediavault-diagnostics-20170922-0957.zip
September 22, 20178 yr Community Expert Syslog rotated and is missing the start of the problems, but disk4 is apparently read-only, so start by running reiserfsck on it: https://wiki.lime-technology.com/Check_Disk_Filesystems#Drives_formatted_with_ReiserFS_using_unRAID_v5_or_later Then reboot and grab new diags if issues continue.
September 22, 20178 yr Author Thanks Johnnie, I will get that reiserfsck running. Appreciate the help!
