May 7, 201016 yr I've had a working 10 drive system for quite some time now with no issues. I had to upgrade my parity to allow the array to grow into 2TB drives. This is the second WDC WD20EADS-00S2B0 drive I've tried to use. In both cases the parity build fails and a DISK_DSBL occurs. I don't believe the issue is with cable or power, since the new drive is using the old parity drive's connectors. I still had my old parity drive in the computer, plugged it back in and used the procedures to "trust" the configuration. The parity check is currently running (a lot longer than the build did using the 2TB drives). Any help would be greatly appreciated! unRAID 4.5 Linux Movie-Server 2.6.31.6-unRAID #6 SMP Thu Dec 3 10:00:15 MST 2009 i686 Intel(R) Pentium(R) Dual CPU E2200 @ 2.20GHz GenuineIntel GNU/Linux preclear output: =========================================================================== = unRAID server Pre-Clear disk /dev/sdl = cycle 1 of 1 = Disk Pre-Clear-Read completed DONE = Step 1 of 10 - Copying zeros to first 2048k bytes DONE = Step 2 of 10 - Copying zeros to remainder of disk to clear it DONE = Step 3 of 10 - Disk is now cleared from MBR onward. DONE = Step 4 of 10 - Clearing MBR bytes for partition 2,3 & 4 DONE = Step 5 of 10 - Clearing MBR code area DONE = Step 6 of 10 - Setting MBR signature bytes DONE = Step 7 of 10 - Setting partition 1 to precleared state DONE = Step 8 of 10 - Notifying kernel we changed the partitioning DONE = Step 9 of 10 - Creating the /dev/disk/by* entries DONE = Step 10 of 10 - Testing if the clear has been successful. DONE = Disk Post-Clear-Read completed DONE Elapsed Time: 29:37:58 ============================================================================ == == Disk /dev/sdl has been successfully precleared == ============================================================================ S.M.A.R.T. error count differences detected after pre-clear note, some 'raw' values may change, but not be an indication of a problem 19,20c19,20 < Offline data collection status: (0x80) Offline data collection activity < was never started. --- > Offline data collection status: (0x84) Offline data collection activity > was suspended by an interrupting command from host. 54c54 < 1 Raw_Read_Error_Rate 0x002f 100 253 051 Pre-fail Always - 0 --- > 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0 58c58 < 7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0 --- > 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 63c63 < 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 58 --- > 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 63 ============================================================================ syslog: May 7 07:07:42 Movie-Server kernel: ata12.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen May 7 07:07:42 Movie-Server kernel: ata12.00: cmd 35/00:00:3f:60:2e/00:04:12:00:00/e0 tag 0 dma 524288 out May 7 07:07:42 Movie-Server kernel: res 40/00:ff:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) May 7 07:07:42 Movie-Server kernel: ata12.00: status: { DRDY } May 7 07:07:42 Movie-Server kernel: ata12: hard resetting link May 7 07:07:43 Movie-Server kernel: ata12: SATA link up 3.0 Gbps (SStatus 123 SControl 300) May 7 07:07:43 Movie-Server kernel: ata12.00: configured for UDMA/133 May 7 07:07:43 Movie-Server kernel: ata12.00: device reported invalid CHS sector 0 May 7 07:07:43 Movie-Server kernel: ata12: EH complete May 7 07:32:59 Movie-Server kernel: ata12.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen May 7 07:32:59 Movie-Server kernel: ata12.00: cmd 35/00:00:3f:2c:b3/00:04:17:00:00/e0 tag 0 dma 524288 out May 7 07:32:59 Movie-Server kernel: res 40/00:ff:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout) May 7 07:32:59 Movie-Server kernel: ata12.00: status: { DRDY } May 7 07:32:59 Movie-Server kernel: ata12: hard resetting link May 7 07:33:09 Movie-Server kernel: ata12: softreset failed (device not ready) May 7 07:33:09 Movie-Server kernel: ata12: hard resetting link May 7 07:33:19 Movie-Server kernel: ata12: softreset failed (device not ready) May 7 07:33:19 Movie-Server kernel: ata12: hard resetting link May 7 07:33:30 Movie-Server kernel: ata12: link is slow to respond, please be patient (ready=0) May 7 07:33:54 Movie-Server kernel: ata12: softreset failed (device not ready) May 7 07:33:54 Movie-Server kernel: ata12: limiting SATA link speed to 1.5 Gbps May 7 07:33:54 Movie-Server kernel: ata12: hard resetting link May 7 07:33:59 Movie-Server kernel: ata12: softreset failed (device not ready) May 7 07:33:59 Movie-Server kernel: ata12: reset failed, giving up May 7 07:33:59 Movie-Server kernel: ata12.00: disabled May 7 07:33:59 Movie-Server kernel: ata12.00: device reported invalid CHS sector 0 May 7 07:33:59 Movie-Server kernel: ata12: EH complete May 7 07:33:59 Movie-Server kernel: sd 12:0:0:0: [sdl] Unhandled error code May 7 07:33:59 Movie-Server kernel: sd 12:0:0:0: [sdl] Result: hostbyte=0x04 driverbyte=0x00 May 7 07:33:59 Movie-Server kernel: end_request: I/O error, dev sdl, sector 397618239 May 7 07:33:59 Movie-Server kernel: md: disk0 write error May 7 07:33:59 Movie-Server kernel: handle_stripe write error: 397618176/0, count: 1 syslog.txt
November 3, 201015 yr Author Unfortunately, I had to just give up using this type of drive and switched to Hitachi HDS722020ALA330.
