November 1, 20179 yr I have a disk that after a reboot just unmounted and could not remount. It says that I need to run Check Filesystem Status since it is a Reiserf disk. I did the "Check" and it came up with the following: reiserfsck 3.6.24 Will read-only check consistency of the filesystem on /dev/md3 Will put log info to 'stdout' reiserfs_open: the reiserfs superblock cannot be found on /dev/md3. Failed to open the filesystem. If the partition table has not been changed, and the partition is valid and it really contains a reiserfs partition, then the superblock is corrupted and you need to run this utility with --rebuild-sb. I ran a check with the --rebuild-sb but it then asked this: reiserfsck 3.6.24 Will check superblock and rebuild it if needed Will put log info to 'stdout' reiserfs_open: the reiserfs superblock cannot be found on /dev/md3. rebuild_sb: wrong version what the version of ReiserFS do you use[1-4] (1) 3.6.x (2) >=3.5.9 (introduced in the middle of 1999) (if you use linux 2.2, choose this one) (3) < 3.5.9 converted to new format (don't choose if unsure) (4) < 3.5.9 (this is very old format, don't choose if unsure) (X) exit Here is where I am stuck I chose "1" but it just goes back to instructions again. How to I get it to complete the rebuild? I put diag too on this post just in case I am missing something. Everything has been working great up until reboot. Been getting a IRQ 19 error but not sure what is causing that. Thanks diagnostics-20171101-0922.zip
November 1, 20179 yr Community Expert If you're sure it's reiser then follow this: https://wiki.lime-technology.com/Check_Disk_Filesystems#Rebuilding_the_superblock
November 2, 20179 yr Author Well ran the --rebuild-sb following the instructions above from Johnnie.Black but no joy it did the SuperBlock without an issue but once I ran --check again it still had some issues with the disk. The disk is /dev/sdd is coming up each time as unmountable, now I really hate to lose the data so is it possible to replace disk and the parity puts it back on? Never had to replace a drive yet. I do have two other issues: Call Traces found on your server and irq 19: nobody cared found on your server I updated the BIOS like some said to fix "irq" error but not joy there. Just got the Call Traces in the last 6 months. Any help would be great. I attached another copy of diag after I ran the " reiserfsck --rebuild-sb" diagnostics-20171102-0028.zip
November 2, 20179 yr Community Expert Post the current output of reiserfsck -check, after --rebuild-sb you usually need to run --rebuild-tree. The call trace is because irq19 got disable, it's usb related, so nothing to do with the disk and usually not serious unless you have usb issues. Edited November 2, 20179 yr by johnnie.black
November 2, 20179 yr Author Humm don't have anything on the USB but keyboard and mouse that is strange. Anyway it told me to do a -rebuild-tree after it so I ran that. It did the rebuild tree all the way but came out saying "no reiserfsck metadata found" Now a newb at most of this how to I get the output? I had to run all this from terminal since it would not work on the GUI part of UnRAID.
November 2, 20179 yr Community Expert 10 minutes ago, gsd2012 said: Now a newb at most of this how to I get the output? Use putty to SSH into the server, then copy/paste
November 2, 20179 yr Author Below is what came out.. _________________________________________________________ root@MistyMtnMedia:~# reiserfsck --rebuild-sb /dev/sdd reiserfsck 3.6.24 Will check superblock and rebuild it if needed Will put log info to 'stdout' Do you want to run this program?[N/Yes] (note need to type Yes if you do):Yes rebuild-sb: wrong tree height occured (65535), zeroed Reiserfs super block in block 16 on 0x830 of format 3.6 with standard journal Count of blocks on the device: 488378640 Number of bitmaps: 14905 Blocksize: 4096 Free blocks (count of blocks - used [journal, bitmaps, data, reserved] blocks): 488378640 Root block: 0 Filesystem is NOT clean Tree height: 0 Hash function used to sort names: "r5" Objectid map size 2, max 972 Journal parameters: Device [0x0] Magic [0x0] Size 8193 blocks (including 1 for journal header) (first block 18) Max transaction length 1024 blocks Max batch size 900 blocks Max commit age 30 Blocks reserved by journal: 0 Fs state field: 0xfa03: FATAL corruptions exist. some corruptions exist. sb_version: 2 inode generation number: 0 UUID: 7852e86a-3d79-4824-8b98-3a914f9be916 LABEL: Set flags in SB: Mount count: 1 Maximum mount count: 30 Last fsck run: Wed Nov 1 12:33:02 2017 Check interval in days: 180 Is this ok ? (y/n)[n]: y The fs may still be unconsistent. Run reiserfsck --check. root@MistyMtnMedia:~# reiserfsck --check Usage: reiserfsck [mode] [options] device Modes: --check consistency checking (default) --fix-fixable fix corruptions which can be fixed without --rebuild-tree --rebuild-sb super block checking and rebuilding if needed (may require --rebuild-tree afterwards) --rebuild-tree force fsck to rebuild filesystem from scratch (takes a long time) --clean-attributes clean garbage in reserved fields in StatDatas Options: -j | --journal device specify journal if relocated -B | --badblocks file file with list of all bad blocks on the fs -l | --logfile file make fsck to complain to specifed file -n | --nolog make fsck to not complain -z | --adjust-size fix file sizes to real size -q | --quiet no speed info -y | --yes no confirmations -f | --force force checking even if the file system is marked clean -V prints version and exits -a and -p some light-weight auto checks for bootup -r ignored Expert options: --no-journal-available do not open nor replay journal -S | --scan-whole-partition build tree of all blocks of the device root@MistyMtnMedia:~# reiserfsck --check /dev/sdd reiserfsck 3.6.24 Will read-only check consistency of the filesystem on /dev/sdd Will put log info to 'stdout' Do you want to run this program?[N/Yes] (note need to type Yes if you do):Yes ########### reiserfsck --check started at Thu Nov 2 12:53:50 2017 ########### Replaying journal: No transactions found Checking internal tree.. Bad root block 0. (--rebuild-tree did not complete) Aborted
November 2, 20179 yr Community Expert 5 minutes ago, gsd2012 said: (--rebuild-tree did not complete) If this is the last one you need to run reiserfsck --rebuild-tree
November 2, 20179 yr Author Here is what happen when I ran "rebuild-tree" MistyMtnMedia:~# reiserfsck --rebuild-tree /dev/sdd reiserfsck 3.6.24 ************************************************************* ** Do not run the program with --rebuild-tree unless ** ** something is broken and MAKE A BACKUP before using it. ** ** If you have bad sectors on a drive it is usually a bad ** ** idea to continue using it. Then you probably should get ** ** a working hard drive, copy the file system from the bad ** ** drive to the good one -- dd_rescue is a good tool for ** ** that -- and only then run this program. ** ************************************************************* Will rebuild the filesystem (/dev/sdd) tree Will put log info to 'stdout' Do you want to run this program?[N/Yes] (note need to type Yes if you do):Yes Replaying journal: No transactions found ########### reiserfsck --rebuild-tree started at Thu Nov 2 14:14:33 2017 ########### Pass 0: ####### Pass 0 ####### Loading on-disk bitmap .. ok, 23115 blocks marked used Skipping 23115 blocks (super block, journal, bitmaps) 0 blocks will be read Could not find a hash in use. Using "r5" "r5" hash is selected Flushing..finished Read blocks (but not data blocks) 0 Leaves among those 0 Objectids found 2 Pass 1 (will try to insert 0 leaves): ####### Pass 1 ####### Looking for allocable blocks .. finished Flushing..finished 0 leaves read 0 inserted ####### Pass 2 ####### Flushing..finished No reiserfs metadata found. If you are sure that you had the reiserfs on this partition, then the start of the partition might be changed or all data were wiped out. The start of the partition may get changed by a partitioner if you have used one. Then you probably rebuilt the superblock as there was no one. Zero the block at 64K offset from the start of the partition (a new super block you have just built) and try to move the start of the partition a few cylinders aside and check if debugreiserfs /dev/xxx detects a reiserfs super block. If it does this is likely to be the right super block version. Aborted
November 2, 20179 yr Community Expert /dev/sdd So only noticed now, why are you running reiserfsck on the device instead of starting the array in maintenance mode and running it on the mdX device? This will make your parity invalid, and worst than that you need to use the partition number, in this case: reiserfsck /dev/sdd1
November 2, 20179 yr Author I am in maintenance mode now and it stated that if the drive is file system type "reiserf" then run the "reiserfsck --check" and follow what it instructs. So should I just run it as you posted above? I was following the instructions on the post you sent me.
November 2, 20179 yr Community Expert 9 minutes ago, gsd2012 said: I was following the instructions on the post you sent me. No you weren't, from the wiki I linked: Quote The example below uses Disk 6 (/dev/md6), so you need to change that to the correct drive symbol for your drive. 9 minutes ago, gsd2012 said: I am in maintenance mode now and it stated that if the drive is file system type "reiserf" then run the "reiserfsck --check" and follow what it instructs. Yes
November 2, 20179 yr Author Oh ok I was a bit confused on the /dev/md6 part so in my case it is drive 3 so /dev/md3 then. Can I run it all again without issue?
November 2, 20179 yr Community Expert Just now, gsd2012 said: Can I run it all again without issue? It should still be OK, first run: reiserfsck /dev/md3 If you get invalid superblock you need to rebuild it again, if you get "Bad root block 0. (--rebuild-tree did not complete)" run with --rebuild-tree.
November 3, 20179 yr Author Ok ran the rebuild-tree which took forever but too big to copy and paste so I am attaching it. I think the drive is fubared. Rebuild-Tree_Output.txt
November 3, 20179 yr Community Expert Doesn't look good, did you have to rebuild the superblock again when using /dev/md3?
November 3, 20179 yr Author Yeah did that with the right stuff and it said it worked but then during the rebuild tree it had all those errors... I am thinking the drive died. Now I hope to switch it out and the data would be recreated from parity but not much faith on that. First time I have lost a drive so far.
