HELP! Fix common problems: Call Traces found on your server
First time posting! Need help!
Fix common problems keeps telling me "Call Traces found on your server" and I have no idea about what is going on. The server works but I just want to be careful since I really cant lose any data.
There is my diagnostics zip. I am not sure if this is what you guys need to help me out. Please tell me anything you need.
Thanks!
unraid-diagnostics-20171108-1441.zip
Nov  8 14:38:12 Unraid kernel: WARNING: CPU: 0 PID: 1 at drivers/iommu/intel-iommu.c:2656 domain_prepare_identity_map+0xb9/0x15a
Nov  8 14:38:12 Unraid kernel: Your BIOS is broken; RMRR ends before it starts!
Look for a bios update for your motherboard.  If you're not using VM's with passthrough, then you can also disable VT-D / IOMMU in the bios and the message will probably go away
Thanks for the fast reply. Since I am using VMs I will try update my bios.
Again, huge thanks
Bad news. I just "updated" my bios and it does not work. The Bios is already on its latest version, I flashed it anyway but the problem still exists.
If you're not seeing any problems, then don't worry about it and ignore the complaint from FCP
The server works fine including all the VMs. I will post any problems after I notice it.
Thanks
