Proper drive replacement for failed parity drive and data drive in dual parity?
I came home this weekend to find my 6.3.5 dual parity system had lost one of its parity drives and a data drive. I immediately overnighted some replacement drives from Amazon, along with a 3rd, which should get here in a few hours
I was curious, what is the proper method for replacing them. Should I do them both at the same time? The data drive first, and then the parity drive? Or vice versa?
Edited by EGOvoruhk
You can replace both at the same time but it's unlikely for two disks to fail simultaneously, you should post your diagnostics.
