December 17, 20178 yr My UnRaid system has been running great for years. A few days ago I had a power outage. Ever sine that my UnRaid system has been unstable. It just randomly crashes. I'll attach a system log as soon as I can get it back up. tower-diagnostics-20171217-1856.zip Edited December 17, 20178 yr by kricker
December 18, 20178 yr Community Expert You have 'Fix Common Problems' installed, turn on the Trouble shooting mode. That will write periodic log files to your logs directory/folder on your flash drive. If someone else does see something first, upload those files after your next crash. You could also post up a picture of your console monitor. (Be sure that that picture is good one-- sharply-focused, non blurry and no flash spot that washes out text.)
December 18, 20178 yr Community Expert It could be worth starting the system on Maintenance mode and running file system checks on all the array drives in case the outage caused some file system level corruption that is causing issues.
December 18, 20178 yr Author I captured this this morning via KVM console. I am currently running with "Fix Common Problems" in troubleshooting mode. Edited December 18, 20178 yr by kricker
