LetsEncrypt Problems after 6.4.0_rc18f upgrade
I just upgraded to 6.4.0_rc18f  and immediately noticed that my letsencrypt server redirect page was no longer working. I checked my docker and found that letsencrypt was not running and could not be started. So, I moved the letsencrypt image and tried to reinstall through Community Apps, however every time I try to reinstall I get an error which tells me that port 443 is already in use. This has never been the case in the past, and no other docker is using port 443. Anyone have any idea how I can fix this? Thanks! See below for the install error:
/usr/bin/docker: Error response from daemon: driver failed programming external connectivity on endpoint letsencrypt (ba8eb657425e3c10dc7c7e2db6706d13c4d829918522bb0dd4bbbcc009a3ae24): Error starting userland proxy: listen tcp 0.0.0.0:443: bind: address already in use.
The command failed.
Change the port to something else than 443 in letsencrypt template, as unraid now uses https.
Yeah, I just realized that UnRaid now uses https and now feel like an idiot ;-)
Thanks though!
