January 13, 20188 yr At first I though I might have imagined it but It happened several times now, I usually click the Unread Content link and start reading threads, then click the browser back button to go back to the unread list, the last thread clicked won't be on the list no more, this is good, now I usually leave threads I believe will take more time to read/reply for the end and the problem is that sometimes, one of these threads will disappear from the unread list without me reading it, this has happened at least 5 or 6 times and makes me wonder if other threads are masked ar read without me noticing, I know this is probably hard to diagnose but I'm sure there's a problem, I'm not crazy
January 13, 20188 yr I have seen the same. I might have 3 unread. I click the third and read. Return to the list and have no unread. Open the other two (no longer marked) threads and they contain unread content at the end. I'm using Chrome. I think I see it more now than a month ago - might it have anything to do with the much more common spam deletions?
January 13, 20188 yr Author 55 minutes ago, pwm said: I'm using Chrome. Firefox here. 55 minutes ago, pwm said: might it have anything to do with the much more common spam deletions? Pretty sure I've seen this before the spam invasion.
January 13, 20188 yr 1 minute ago, johnnie.black said: Pretty sure I've seen this before the spam invasion. I have seen it before the spam invasion too. Just have a feeling I might see it more lately than one month ago. But that might also be because I have visited much more threads and subfora.
January 13, 20188 yr Happens to me as well. If you go to the "normal" forum view, you will see which subforums contain unread content by the icon change, yet unread lists clear. It's been happening to me since the forum change. My suspicion is that it has to do with the filters, because the forum really does know what threads you've visited, it updates the icons in the main list properly.
January 13, 20188 yr I just had it happen. When I clicked on "Activity", it showed an unread post, even though unread content showed nothing. Next time it happens to you, try clicking on Activity beside home on the unread content page. It points to https://lime-technology.com/discover/
January 16, 20188 yr Just saw the issue again. Had three unread threads. Visited the third. When I returned out, I had zero unread threads. The topmost thread had just about at the same time received a new post. So it seems like there may be some race condition between two users that results in the error.
January 17, 20188 yr I just saw another strange thing with the unread threads logic. In the announce subforum, I came back out from having read all new posts in the release thread for 6.4.0. Suddenly had two unread threads - the release thread I had just visited and the new thread with update notes. Clicked once more the bullet for the release thread and got sent to the first post. Manually clicked last page - no new post to find. Then exited and still had the same two threads unread. Repeated the same action once more with the same result. Trying to read the announce thread just could not clear any unread bullets - and never had any unread posts to read. Clicked instead on the bullet for the update notes thread. Noticed it had received a third post - and that the first post was edited. Exited that thread and that cleared the update notes for both the update notes thread and the 6.4.0 release thread. Not sure if this is related, but the first post in the update notes thread was to my knowledge originally a post of the 6.4.0 release thread but moved into a separate thread. Does the forum get a "phantom binding" between threads when a post has been moved between threads? And will an edit of the moved post turn on "unread" for both the new and original thread?
January 25, 20188 yr Author This is still happening, just had another post disappear from the unread list.
March 24, 20188 yr Right now I have the reverse. I have an icon showing that I have unread threads in General Support. But if I open General Support there is no unread thread. If I wait until someone makes a new post in General Support, and I read that thread, the thread doesn't show any "next unread". Only way to clear this mismatch is to mark "All read" for General Support.
September 19, 20187 yr Author Just an FYI this is still happening, it happens so many times that I now try to just browse the forums instead of clicking the unread list or I keep missing posts that are wrongly marked as read.
September 20, 20187 yr Author 16 hours ago, johnnie.black said: now try to just browse the forums instead of clicking the unread list or I keep missing posts that are wrongly marked as read. Well, this doesn't work, posts are also marked read when browsing without actually reading them, at least they do on the Bug Reports suf-forum, haven't noticed this yet on the main forums, so hopefully it's limited to that one.
April 14, 20197 yr Author This it still happening, every day, over a year after initial reporting, kind of disappointing it's not fixed yet.
January 14, 20206 yr Author On 1/13/2018 at 11:44 AM, johnnie.black said: FYI, 2 years later this is still happening on a daily basis.
