January 15, 20188 yr I'm trying to set up a remote UnRaid server I have as an FTP server. I know that UnRaid has FTP built in, but I haven't had any luck finding any guides on how to set it up and use it. Anyone who is knowledgable and can help me out? I would greatly appreciate it!
January 15, 20188 yr When you say "remote" - do you mean you want to access it over Internet? Remember that you then needs some encrypted tunnel to protect your machine and your data. Ftp will send all data - and your account+password - unencrypted. Unless you are using a VPN, it's way safer to look at any solution that can tunnel the transfers in an SSH tunnel. So maybe scp, rsync, ... Edited January 15, 20188 yr by pwm
