Problem with VMs, tried a solution, now unRAID won't boot
I've been having issues running VMs with GPU pass through.  I tried override option but i still cannot enable pass through.  The first VM I created did allow GPU pass through but now no other VMs i create will allow it.  I'm using an R410 (Matrox g200eW)with unRAID 6.4.1.  I tried adding ",multifunction" to the syslinux config, but after rebooting, the server is not accessible.  How can I fix this issue?
Did you enable IOMMU passthrough in your motherboard settings?
Yes, I did.
perhaps you GPU is a bit outdated  B|
