CA fix common problems show drive has read errors
So I am getting this warning today for disk6.  I click on the disk6 settings and don't see anything.  How can I verify this and clear the error if drive is ok?
The errors will show up in the Main tab.  You should post your diagnostics for people to review.
It was a disk error, the disk is showing some warnings on SMART, you can run an extended SMART test, though since the problem sectors were successfully written back it might pass, still even if it passes start planning to replace as it's just a matter of time.
