March 10, 20188 yr Hello, I recently upgraded to 6.4.1 without any issue after a week or two I enabled vlan support in networking. I think it's coincident but I'm not receiving errors. "Error: Call Traces found on your server" "Unraid kernel: sas: Enter sas_scsi_recover_host busy: 1 failed: 1" "Unraid sSMTP[31412]: Authorization failed (535 5.7.8 https://support.google.com/mail/?p=BadCredentials " "Unraid kernel: CPU: 6 PID: 13004 Comm: kworker/6:0 Not tainted 4.14.16-unRAID #1" Diagnostics attached. Any help would be appreciated. unraid-diagnostics-20180309-1841.zip
March 10, 20188 yr Community Expert 4 hours ago, pangklee said: "Error: Call Traces found on your server" They are related to macvlan, are you assigning custom IPs to dockers? 4 hours ago, pangklee said: "Unraid kernel: sas: Enter sas_scsi_recover_host busy: 1 failed: 1" You can ignore this.
March 10, 20188 yr Author 41 minutes ago, johnnie.black said: They are related to macvlan, are you assigning custom IPs to dockers? You can ignore this. Yes I am. I’m assigning an ip to both my home assistant and home bridge dockers. Is this normal behavior? would be able to share the cause of the errors I can ignore?
March 10, 20188 yr Community Expert I never used it but you're not the first with related call traces, you can try upgrading to latest 6.5rc or redoing the custom IPs config.
