March 27, 20188 yr Help with using hardware transcoding (Emby/Plex) Hello, I need to use HW transcoding to left the weight off CPU. I have this motherboard: Supermicro X11SSH-CTF https://www.supermicro.com/products/motherboard/Xeon/C236_C232/X11SSH-CTF.cfm Graphics: Aspeed AST2400 BMC CPU: Intel Xeon E3-1245 V5 Integrated Graphics: Intel HD Graphics P530 When I create a VM I can choose between the two GPUs as shown below: And according to Supermicro manual the motherboard support Intel IGD: https://www.supermicro.com/manuals/motherboard/C236/MNL-1783.pdf I want to able to use “Intel HD Graphics P530” for hardware transcoding. I installed Emby and did the following: When I stream a video and check the CPU utilization it hits the 75% ~ 80%: Any help is appreciated.
September 3, 20196 yr Are you using Plex or Emby from within a VM or are you using the Docker containers? To my knowledge QuickSync video encoding cannot be used from a VM. I've read that even if you pass the onboard video through to a VM it's not possible for that part of the hardware to work. It IS possible to use QuickSync encoding from the Emby or Plex Docker containers. You put the following in your /boot/config/go file: modprobe i915 chmod -R 777 /dev/dri chown -R nobody:users /dev/dri Then pass the /dev/dri device to your Plex and/or Emby Docker containers.
