March 31, 20188 yr Hello, I am new to building an Unraid system and looking for feedback for the two systems, I picked. I would like to know from you, if I chose the parts wisely or if there are better options, e.g. better price/performance ratio. I would also like to hear an estimation for the power consumption, as electricity is very expensive in my country (0.29 €/kWh). Technically the "Casual" build should be enough for my needs, since I will use the system as a NAS and Plex Server with just a few clients to serve and usually without transcoding. Best regards, Hercules Casual - 1000 € 2 Western Digital WD Red 8TB, 3.5", SATA 6Gb/s (WD80EFZX) 1 Samsung SSD 960 EVO 500GB, M.2 (MZ-V6E500BW) 1 Intel Pentium Gold G4560, 2x 3.50GHz, boxed (BX80677G4560) 1 Crucial DIMM Kit 8GB, DDR4-2400, CL17 (CT2K4G4DFS824A) 1 Gigabyte GA-B250M-DS3H 1 Fractal Design Define R5 Black, schallgedämmt (FD-CA-DEF-R5-BK) 1 SanDisk Cruzer Fit 8GB, USB-A 2.0 (SDCZ33-008G-B35) 1 be quiet! Pure Power 10-CM 400W ATX 2.4 (BN276) Pro - 1300 € 2 Western Digital WD Red 8TB, 3.5", SATA 6Gb/s (WD80EFZX) 1 Samsung SSD 960 EVO 500GB, M.2 (MZ-V6E500BW) 1 Intel Xeon E3-1225 v6, 4x 3.30GHz, boxed (BX80677E31225V6) 1 Kingston ValueRAM Server Premier DIMM 8GB, DDR4-2400, CL17-17-17, ECC (KVR24E17S8/8MA) 1 Supermicro X11SSH-F retail (MBD-X11SSH-F-O) 1 Fractal Design Define R5 Black, schallgedämmt (FD-CA-DEF-R5-BK) 1 SanDisk Cruzer Fit 8GB, USB-A 2.0 (SDCZ33-008G-B35) 1 be quiet! Pure Power 10-CM 400W ATX 2.4 (BN276) Edited March 31, 20188 yr by Hercules Add total price for both systems
March 31, 20188 yr That be quiet! PSU is split rail, as is all the be quiet! PSUs I have looked at. This means some of the power won't be available for disks. The recommendation is to use PSU with Single +12V rail.
March 31, 20188 yr Author Thanks for you reply. I just checked the specifications for both, the WD Red 8TB HDD and the be quiet! Pure Power 10 PSU. One HDD has a max. current of 1.79A, the 12V1 can deliver 28A and the 12V2 20A. The 12V2 20A rail would be enough to run 11 HDDs and I am not planning to get that many drives. Edited March 31, 20188 yr by Hercules typo; replace , with . for the americans
March 31, 20188 yr I'm scratching my head around your drives: 2x spinner and 1x M.2. What are your plans? AFAIK, you can't use the M.2 as a parity or data drive. It would be a fast Cache or Unassigned Devices drive. But what to do with 2 drives? 1x parity and 1x data? Power? Yes! That hurts. I pay 0,33 EUR currently here in NRW. My two machines with 46 drives do cost me an arm and a leg ?
March 31, 20188 yr Author Hey hawihoney, one HDD will be my parity drive and the other one will be used as storage drive (for now). I am planning to use the M.2 SSD as Cache, if that isn't a problem. I chose a M.2 SSD because I don't want to "waste" a SATA slot for it. In the future I want to add additional storage drives and another parity drive. Edited March 31, 20188 yr by Hercules
March 31, 20188 yr IMHO, M.2 as Cache should work. I use 860 Pro SSDs as Cache because my Supermicro motherboards don't have these M.2 slots. Would love to have some. The difference between spinner and SSD was remarkable (~factor 3), M.2 adds ~factor 4 to my SSDs.
April 3, 20188 yr Just a note, M.2 is the format of the SSD. You can get SATA M.2, PCI-E AHCI M.2, and of course PCI-E NVMe M.2. SATA M.2 usually defeat one of your normal SATA connections, so they're best avoided. PCI-E AHCI are OK, but I don't see them much now - I have a Samsung OEM AHCI M.2 somewhere and it works fine. unRAID supports all three types of M.2.
