April 22, 20188 yr This is my setup M/B: Gigabyte Technology Co., Ltd. - GA-990XA-UD3 CPU: AMD FX™-8120 Eight-Core @ 3100 Unraid version 6.5.0 After an electrical failure in the town I live in, this error always occurs I have scanned the usb drive on another computer and replaced usb port Quote Execution error internal error: process exited while connecting to monitor: 2018-04-22T10:12:41.319793Z qemu-system-x86_64: -drive file=/mnt/disks/Drive01/VM-Domain/vdisk TheTouch.img,format=raw,if=none,id=drive-virtio-disk2,cache=writeback: Could not open '/mnt/disks/Drive01/VM-Domain/vdisk TheTouch.img': Read-only file system
April 23, 20188 yr Apr 22 09:33:08 Skynet ntfs-3g[4433]: Mounted /dev/sdb1 (Read-Only, label "", NTFS 3.1) ... Apr 22 09:33:08 Skynet unassigned.devices: Mount error: The disk contains an unclean file system (0, 0). Metadata kept in Windows cache, refused to mount. Falling back to read-only mount because the NTFS partition is in an unsafe state. Please resume and shutdown Windows fully (no hibernation or fast restarting.) You need to check filesystem on that disk.
