April 26, 20188 yr I currently have a X11SSH-LN4F laying around that i want to re-purpose for unraid. 20x WD red sata 6Gb/s drives for data and 2-4x Samsung 860 EVO 500GB sata 6gb/s is what im going to stuff the nas with. Since the board doesn't have 24 sata or sas ports means that i have to get a controller. Im also planing on getting 10Gb network with the goal of having a whooping 1GB/s transfer speed. But this sacrifice one pcie x8 slot for the NIC, leaving me one x8 and one x4 slot for a controller that unraid can use. So my questions are: 1. Looking at the LSI SAS 9305-24i (pcie x8, SATA 12Gb/s) is it enough for my setup without a bottleneck? 2. Is it better to use 2 controllers rather then 1 controller for all the drives if i want 10GB/s speed? 3. Any other recommendation on controller that are more suited for my situation?
April 26, 20188 yr 23 minutes ago, r4ptor said: 1. Looking at the LSI SAS 9305-24i (pcie x8, SATA 12Gb/s) is it enough for my setup without a bottleneck? Yes 23 minutes ago, r4ptor said: Is it better to use 2 controllers rather then 1 controller for all the drives if i want 10GB/s speed? Assuming you mean 1GB/s you'll never get that with that hardware, unRAID doesn't stripe disks, you can still get a decent speed writing to the SSDs if in a cache pool, but for 1GB/s you'd need NVMe, writing to the array will max out at around 150MB/s.
April 26, 20188 yr Author 1 hour ago, johnnie.black said: Assuming you mean 1GB/s you'll never get that with that hardware, unRAID doesn't stripe disks, you can still get a decent speed writing to the SSDs if in a cache pool, but for 1GB/s you'd need NVMe, writing to the array will max out at around 150MB/s. Of course I meant 1 GigaByte transfer speed between PC and NAS in a 10 Gigabit network. I reed somewhere on this forum that its possible to stripe the cache drives but not the data drives. If this works then i wont be needing a NVMe but rather 2 regular SSDs That 150MB/s you speak of would be the bottleneck in a 1Gb network but internaly from cache to array would be limited to up to 600MB/s as per SATA3.
April 26, 20188 yr 8 minutes ago, r4ptor said: That 150MB/s you speak of would be the bottleneck in a 1Gb network but internaly from cache to array would be limited to up to 600MB/s as per SATA3. No, cache to array can only go as fast as the array can be written. No striping in array as mentioned and there is also some write speed penalty to update parity even with turbo write. And even without the parity update HDDs can't saturate sata3 anyway. https://lime-technology.com/forums/topic/50397-turbo-write/
April 27, 20188 yr 11 hours ago, r4ptor said: I reed somewhere on this forum that its possible to stripe the cache drives but not the data drives. If this works then i wont be needing a NVMe but rather 2 regular SSDs You can but with two SATA SSDs you won't get close to 1GB/s, more like 600MB/s. 11 hours ago, r4ptor said: That 150MB/s you speak of would be the bottleneck in a 1Gb network but internaly from cache to array would be limited to up to 600MB/s as per SATA3. No, that's the max speed the array will be able to write, from anywhere.
April 27, 20188 yr Author 19 hours ago, trurl said: No, cache to array can only go as fast as the array can be written. No striping in array as mentioned and there is also some write speed penalty to update parity even with turbo write. And even without the parity update HDDs can't saturate sata3 anyway. 8 hours ago, johnnie.black said: No, that's the max speed the array will be able to write, from anywhere. Sure, from the cache to the array of data disk, this will be slow as johnnie.black stated earlier. But i want 1GB/s from my PC to the "cache", if it then takes 10min for 1GB from the cache to the data disks isn't that important, right now atleast 8 hours ago, johnnie.black said: You can but with two SATA SSDs you won't get close to 1GB/s, more like 600MB/s. are you suggesting that i go for 4x SSD then?
April 27, 20188 yr 8 minutes ago, r4ptor said: are you suggesting that i go for 4x SSD then? Best would be a couple (or just one if no redundancy is needed) of NVMe devices, but test just those two SSDs, it might get closer to 1GB/s than I think using raid0. Edited April 27, 20188 yr by johnnie.black
May 6, 20188 yr Author Thanks for your tip jonnie.black, ive been reading up on this topic and you seem to be right. i decided to go witha norco 4324 case, 24 bay with 6 sas backplanes (1 per row of 4 drives) but i might need some suggestion on a new controller, the 9305-24i is a huge hole in my wallet. Is there a good sas expander + controller combo that can handle 24 drive with no bottleneck? (preferable cheaper too) Does the sas expander need a pcie slot for data or could i simply use a riser to power it since im running out of slots on my motherboard?
May 7, 20188 yr For 16 disks you could go with an LSI 9207-8i plus an Intel RES2SV240, for more you'd need an Intel RES2CV360 but those are usually expensive, even used.
May 8, 20188 yr Author cant find a RES2CV360 for sale anyway How about the Intel RES3TV360 with a LSI 9300-8I? both seem to support 12Gb/s and combined they go for $400-420 instead of $620 for a 9305-24i Is it possible to use one of these just to power the explander?
May 8, 20188 yr 14 minutes ago, r4ptor said: How about the Intel RES3TV360 with a LSI 9300-8I? Better yet. 15 minutes ago, r4ptor said: Is it possible to use one of these just to power the explander? Expander is powered by a molex plug.
May 8, 20188 yr Author 1 hour ago, johnnie.black said: Expander is powered by a molex plug. Your right, I mixed it up for another card. Will there be a bottleneck in the performance doit it this way with a sas expander? (just found this page)
May 8, 20188 yr If using dual link you'll have at least 4400MB/s for all the disks, so with 24 disks 183MB/s per disk, which is more than a WD Red max speed, and possible around 7000MB/s with LSI's databolt technology, assuming the RES3TV360 uses an LSI chipset*. * Edit: It doesn't, it uses a PMC chipset, so no Databolt Edited April 26, 20197 yr by johnnie.black
