April 27, 20188 yr I have a flaky drive that I am trying to replace. The replacement drive is from an Unraid server we had a work that we never used. Its the same model drive as the "bad" drive. Putting the new drive in, I am getting a drive too small error. Seeing all the post about HPA are a little confusing to me. I do see a reference to HPA in my syslog but am wondering if its just on this new drive (from the old system) or if I have to do something else. Can someone walk me through what I have to do here? Thanks! Scott Here is my syslog: https://pastebin.com/w7pE7nTH
April 27, 20188 yr Community Expert HPA is enable: Apr 27 09:22:48 Unraid kernel: ata4.00: HPA detected: current 3907027055, native 3907029168 Apr 27 09:22:48 Unraid kernel: ata4.00: ATA-8: WDC WD20EARS-00MVWB0, WD-WMAZA4161733, 51.0AB51, max UDMA/133 See here to disable:
April 27, 20188 yr Author Thanks! Looks like it was from the old system. I was able to run a: hdparm -N p1953525168 /dev/sde and reboot. It still shows as disabled and rebuilding now. Thank you!
