August 2, 20196 yr 2 hours ago, bally12345 said: Running very smoothly, cpu temps stay around 30c, no real snags other than its probably not the most power efficient compared to newer gen stuff but I can live with that given the price. How would you describe the noise level and characteristic? Understand it's in the basement so it's not an issue for you but I think it would be useful for others who may be considering building a similar server but don't have isolated spaces.
August 2, 20196 yr Author How would you describe the noise level and characteristic? Understand it's in the basement so it's not an issue for you but I think it would be useful for others who may be considering building a similar server but don't have isolated spaces.Definitely loud and not really suitable for any living space. You could probably get away with keeping in loft space or under the stairs but then airflow will be an issue.Quieter fans are available but iv got the stock ones which are not too bad imo.The server I bought also as redundant PSU so those add to noise levels. Sent from my SM-G973F using Tapatalk
