June 26, 20188 yr Hi guys, I am ALMOST done setting up my unraid server to be exactly how I want everything. I am so excited. The last issue I am having is with passing through my external USB sound card that I have to the VMs im using (Ubuntu, Windows 10). I have a M-Audio 2x2m sound card and i've attempted to follow Spaceinvader ones guide on how to pass through the audio( First, here are the USB Bus's Bus 1 --> 0000:00:14.0 (IOMMU group 3) Bus 001 Device 007: ID 046d:085b Logitech, Inc. Bus 001 Device 006: ID 046d:c083 Logitech, Inc. G403 Prodigy Gaming Mouse Bus 001 Device 005: ID 0bda:5411 Realtek Semiconductor Corp. Bus 001 Device 004: ID 046d:c337 Logitech, Inc. Bus 001 Device 002: ID 0bda:5411 Realtek Semiconductor Corp. Bus 001 Device 003: ID 1e71:170e NZXT Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 2 --> 0000:00:14.0 (IOMMU group 3) Bus 002 Device 003: ID 0951:1666 Kingston Technology DataTraveler 100 G3/G4/SE9 G2 Bus 002 Device 004: ID 0bda:0411 Realtek Semiconductor Corp. Bus 002 Device 002: ID 0bda:0411 Realtek Semiconductor Corp. Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 3 --> 0000:05:00.0 (IOMMU group 13) Bus 003 Device 002: ID 0763:400c M-Audio Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 4 --> 0000:05:00.0 (IOMMU group 13) Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub We see the M-audio in Bus 3 and IOMMU Group 13. Then Running the second command to look through Iommu groups : for iommu_group in $(find /sys/kernel/iommu_groups/ -maxdepth 1 -mindepth 1 -type d);do echo "IOMMU group $(basename "$iommu_group")"; for device in $(\ls -1 "$iommu_group"/devices/); do if [[ -e "$iommu_group"/devices/"$device"/reset ]]; then echo -n "[RESET]"; fi; echo -n $'\t';lspci -nns "$device"; done; done IOMMU group 7 [RESET] 00:1c.0 PCI bridge [0604]: Intel Corporation 200 Series PCH PCI Express Root Port #1 [8086:a290] (rev f0) IOMMU group 15 [RESET] 07:00.0 Non-Volatile memory controller [0108]: Samsung Electronics Co Ltd NVMe SSD Controller SM961/PM961 [144d:a804] IOMMU group 5 00:17.0 SATA controller [0106]: Intel Corporation 200 Series PCH SATA controller [AHCI mode] [8086:a282] IOMMU group 13 [RESET] 05:00.0 USB controller [0c03]: ASMedia Technology Inc. Device [1b21:2142] IOMMU group 3 00:14.0 USB controller [0c03]: Intel Corporation 200 Series PCH USB 3.0 xHCI Controller [8086:a2af] IOMMU group 11 00:1f.0 ISA bridge [0601]: Intel Corporation Device [8086:a2c9] 00:1f.2 Memory controller [0580]: Intel Corporation 200 Series PCH PMC [8086:a2a1] 00:1f.3 Audio device [0403]: Intel Corporation 200 Series PCH HD Audio [8086:a2f0] 00:1f.4 SMBus [0c05]: Intel Corporation 200 Series PCH SMBus Controller [8086:a2a3] IOMMU group 1 00:01.0 PCI bridge [0604]: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x16) [8086:1901] (rev 07) 00:01.1 PCI bridge [0604]: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x8) [8086:1905] (rev 07) 01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GP102 [GeForce GTX 1080 Ti] [10de:1b06] (rev a1) 01:00.1 Audio device [0403]: NVIDIA Corporation GP102 HDMI Audio Controller [10de:10ef] (rev a1) 02:00.0 VGA compatible controller [0300]: NVIDIA Corporation GP102 [GeForce GTX 1080 Ti] [10de:1b06] (rev a1) 02:00.1 Audio device [0403]: NVIDIA Corporation GP102 HDMI Audio Controller [10de:10ef] (rev a1) IOMMU group 8 [RESET] 00:1c.4 PCI bridge [0604]: Intel Corporation 200 Series PCH PCI Express Root Port #5 [8086:a294] (rev f0) IOMMU group 6 [RESET] 00:1b.0 PCI bridge [0604]: Intel Corporation 200 Series PCH PCI Express Root Port #17 [8086:a2e7] (rev f0) IOMMU group 14 [RESET] 06:00.0 Ethernet controller [0200]: Aquantia Corp. AQC108 NBase-T/IEEE 802.3bz Ethernet Controller [AQtion] [1d6a:d108] (rev 02) IOMMU group 4 00:16.0 Communication controller [0780]: Intel Corporation 200 Series PCH CSME HECI #1 [8086:a2ba] IOMMU group 12 [RESET] 00:1f.6 Ethernet controller [0200]: Intel Corporation Ethernet Connection (2) I219-V [8086:15b8] IOMMU group 2 [RESET] 00:02.0 VGA compatible controller [0300]: Intel Corporation Device [8086:3e92] IOMMU group 10 [RESET] 00:1d.0 PCI bridge [0604]: Intel Corporation 200 Series PCH PCI Express Root Port #9 [8086:a298] (rev f0) IOMMU group 0 00:00.0 Host bridge [0600]: Intel Corporation 8th Gen Core Processor Host Bridge/DRAM Registers [8086:3ec2] (rev 07) IOMMU group 9 [RESET] 00:1c.6 PCI bridge [0604]: Intel Corporation 200 Series PCH PCI Express Root Port #7 [8086:a296] (rev f0) I find IOMMU 13 and the device id there. 1b21:2142 So I go to the Flash disk and add this - default menu.c32 menu title Lime Technology, Inc. prompt 0 timeout 50 label unRAID OS kernel /bzimage append initrd=/bzroot label unRAID OS GUI Mode menu default kernel /bzimage append vfio-pci.ids=1b21:2142 initrd=/bzroot,/bzroot-gui label unRAID OS Safe Mode (no plugins, no GUI) kernel /bzimage append initrd=/bzroot unraidsafemode label unRAID OS GUI Safe Mode (no plugins) kernel /bzimage append initrd=/bzroot,/bzroot-gui unraidsafemode label Memtest86+ kernel /memtest After I do that, I see the ASMedia Technology Inc device just fine, so I select that in the VM set up. I try to start the VM and i get this error: 2018-06-26 13:56:25.680+0000: starting up libvirt version: 4.0.0, qemu version: 2.11.1, hostname: aiusLC_ALL=C PATH=/bin:/sbin:/usr/bin:/usr/sbin HOME=/ QEMU_AUDIO_DRV=none /usr/local/sbin/qemu -name guest=Ubuntu,debug-threads=on -S -object secret,id=masterKey0,format=raw,file=/var/lib/libvirt/qemu/domain-3-Ubuntu/master-key.aes -machine pc-q35-2.11,accel=kvm,usb=off,dump-guest-core=off,mem-merge=off -cpu host -m 8192 -realtime mlock=off -smp 6,sockets=1,cores=3,threads=2 -uuid 07eed3ae-03a1-9172-c0ad-fc14b4ae749d -display none -no-user-config -nodefaults -chardev socket,id=charmonitor,path=/var/lib/libvirt/qemu/domain-3-Ubuntu/monitor.sock,server,nowait -mon chardev=charmonitor,id=monitor,mode=control -rtc base=utc,driftfix=slew -global kvm-pit.lost_tick_policy=delay -no-hpet -no-shutdown -boot strict=on -device pcie-root-port,port=0x8,chassis=1,id=pci.1,bus=pcie.0,multifunction=on,addr=0x1 -device pcie-root-port,port=0x9,chassis=2,id=pci.2,bus=pcie.0,addr=0x1.0x1 -device pcie-root-port,port=0xa,chassis=3,id=pci.3,bus=pcie.0,addr=0x1.0x2 -device pcie-root-port,port=0xb,chassis=4,id=pci.4,bus=pc2018-06-26 13:56:25.680+0000: Domain id=3 is tainted: high-privileges2018-06-26 13:56:25.680+0000: Domain id=3 is tainted: host-cpu2018-06-26T13:56:25.711246Z qemu-system-x86_64: -chardev pty,id=charserial0: char device redirected to /dev/pts/0 (label charserial0)2018-06-26T13:56:30.622585Z qemu-system-x86_64: vfio_err_notifier_handler(0000:05:00.0) Unrecoverable error detected. Please collect any data possible and then kill the guest2018-06-26T13:56:47.845932Z qemu-system-x86_64: vfio_err_notifier_handler(0000:05:00.0) Unrecoverable error detected. Please collect any data possible and then kill the guest I then tried to follow this guide - After doing that and attempting to start the VM it told me that it couldn't start the VM because the bus was already in use. So, I am stuck. I would greatly appreciate any help anyone might be able to provide. Thank you! Grant Some more information in case its needed - IOMMU group 0: [8086:3ec2] 00:00.0 Host bridge: Intel Corporation 8th Gen Core Processor Host Bridge/DRAM Registers (rev 07) IOMMU group 1: [8086:1901] 00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x16) (rev 07) [8086:1905] 00:01.1 PCI bridge: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor PCIe Controller (x8) (rev 07) [10de:1b06] 01:00.0 VGA compatible controller: NVIDIA Corporation GP102 [GeForce GTX 1080 Ti] (rev a1) [10de:10ef] 01:00.1 Audio device: NVIDIA Corporation GP102 HDMI Audio Controller (rev a1) [10de:1b06] 02:00.0 VGA compatible controller: NVIDIA Corporation GP102 [GeForce GTX 1080 Ti] (rev a1) [10de:10ef] 02:00.1 Audio device: NVIDIA Corporation GP102 HDMI Audio Controller (rev a1) IOMMU group 2: [8086:3e92] 00:02.0 VGA compatible controller: Intel Corporation Device 3e92 IOMMU group 3: [8086:a2af] 00:14.0 USB controller: Intel Corporation 200 Series PCH USB 3.0 xHCI Controller IOMMU group 4: [8086:a2ba] 00:16.0 Communication controller: Intel Corporation 200 Series PCH CSME HECI #1 IOMMU group 5: [8086:a282] 00:17.0 SATA controller: Intel Corporation 200 Series PCH SATA controller [AHCI mode] IOMMU group 6: [8086:a2e7] 00:1b.0 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #17 (rev f0) IOMMU group 7: [8086:a290] 00:1c.0 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #1 (rev f0) IOMMU group 8: [8086:a294] 00:1c.4 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #5 (rev f0) IOMMU group 9: [8086:a296] 00:1c.6 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #7 (rev f0) IOMMU group 10: [8086:a298] 00:1d.0 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #9 (rev f0) IOMMU group 11: [8086:a2c9] 00:1f.0 ISA bridge: Intel Corporation Device a2c9 [8086:a2a1] 00:1f.2 Memory controller: Intel Corporation 200 Series PCH PMC [8086:a2f0] 00:1f.3 Audio device: Intel Corporation 200 Series PCH HD Audio [8086:a2a3] 00:1f.4 SMBus: Intel Corporation 200 Series PCH SMBus Controller IOMMU group 12: [8086:15b8] 00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (2) I219-V IOMMU group 13: [1b21:2142] 05:00.0 USB controller: ASMedia Technology Inc. Device 2142 IOMMU group 14: [1d6a:d108] 06:00.0 Ethernet controller: Aquantia Corp. AQC108 NBase-T/IEEE 802.3bz Ethernet Controller [AQtion] (rev 02) IOMMU group 15: [144d:a804] 07:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM961/PM961 CPU Thread Pairings Pair 1: cpu 0 / cpu 6 Pair 2: cpu 1 / cpu 7 Pair 3: cpu 2 / cpu 8 Pair 4: cpu 3 / cpu 9 Pair 5: cpu 4 / cpu 10 Pair 6: cpu 5 / cpu 11 USB Devices Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 002: ID 0bda:5411 Realtek Semiconductor Corp. Bus 001 Device 003: ID 1e71:170e NZXT Bus 001 Device 004: ID 046d:c337 Logitech, Inc. Bus 001 Device 005: ID 0bda:5411 Realtek Semiconductor Corp. Bus 001 Device 006: ID 046d:c083 Logitech, Inc. G403 Prodigy Gaming Mouse Bus 001 Device 007: ID 046d:085b Logitech, Inc. Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 002 Device 002: ID 0bda:0411 Realtek Semiconductor Corp. Bus 002 Device 003: ID 0951:1666 Kingston Technology DataTraveler 100 G3/G4/SE9 G2 Bus 002 Device 004: ID 0bda:0411 Realtek Semiconductor Corp. SCSI Devices [0:0:0:0] disk Kingston DataTraveler 3.0 PMAP /dev/sda 15.5GB [1:0:0:0] disk ATA WDC WD50EFRX-68L 0A82 /dev/sdb 5.00TB [2:0:0:0] disk ATA ST8000VN0022-2EL SC61 /dev/sdc 8.00TB aius-diagnostics-20180626-1602.zip Edited June 26, 20188 yr by grantphillips
June 26, 20188 yr Author I will also paste my windows XML here in case that helps. This is the none passthrough version that causes terrible audio. I'd really appreciate some advice here! I am quite stuck. <domain type='kvm' id='3'> <name>Windows 10</name> <uuid>d8bca2f1-b24d-0beb-e753-b45f56ead421</uuid> <metadata> <vmtemplate xmlns="unraid" name="Windows 10" icon="windows.png" os="windows10"/> </metadata> <memory unit='KiB'>8388608</memory> <currentMemory unit='KiB'>8388608</currentMemory> <memoryBacking> <nosharepages/> </memoryBacking> <vcpu placement='static'>6</vcpu> <cputune> <vcpupin vcpu='0' cpuset='1'/> <vcpupin vcpu='1' cpuset='7'/> <vcpupin vcpu='2' cpuset='3'/> <vcpupin vcpu='3' cpuset='9'/> <vcpupin vcpu='4' cpuset='5'/> <vcpupin vcpu='5' cpuset='11'/> </cputune> <resource> <partition>/machine</partition> </resource> <os> <type arch='x86_64' machine='pc-i440fx-2.11'>hvm</type> <loader readonly='yes' type='pflash'>/usr/share/qemu/ovmf-x64/OVMF_CODE-pure-efi.fd</loader> <nvram>/etc/libvirt/qemu/nvram/d8bca2f1-b24d-0beb-e753-b45f56ead421_VARS-pure-efi.fd</nvram> </os> <features> <acpi/> <apic/> <hyperv> <relaxed state='on'/> <vapic state='on'/> <spinlocks state='on' retries='8191'/> <vendor_id state='on' value='none'/> </hyperv> </features> <cpu mode='host-passthrough' check='none'> <topology sockets='1' cores='3' threads='2'/> </cpu> <clock offset='localtime'> <timer name='hypervclock' present='yes'/> <timer name='hpet' present='no'/> </clock> <on_poweroff>destroy</on_poweroff> <on_reboot>restart</on_reboot> <on_crash>restart</on_crash> <devices> <emulator>/usr/local/sbin/qemu</emulator> <disk type='file' device='disk'> <driver name='qemu' type='raw' cache='none'/> <source file='/mnt/disks/Samsung_SSD_960_PRO_512GB_S3EWNWAJ329936F/Windows 10/vdisk1.img'/> <backingStore/> <target dev='hdc' bus='virtio'/> <boot order='1'/> <alias name='virtio-disk2'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x04' function='0x0'/> </disk> <disk type='file' device='cdrom'> <driver name='qemu' type='raw'/> <source file='/mnt/user/isos/virtio-win-0.1.141-1.iso'/> <backingStore/> <target dev='hdb' bus='ide'/> <readonly/> <alias name='ide0-0-1'/> <address type='drive' controller='0' bus='0' target='0' unit='1'/> </disk> <controller type='usb' index='0' model='qemu-xhci' ports='15'> <alias name='usb'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x07' function='0x0'/> </controller> <controller type='pci' index='0' model='pci-root'> <alias name='pci.0'/> </controller> <controller type='ide' index='0'> <alias name='ide'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x1'/> </controller> <controller type='virtio-serial' index='0'> <alias name='virtio-serial0'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x0'/> </controller> <interface type='bridge'> <mac address='52:54:00:90:88:67'/> <source bridge='br0'/> <target dev='vnet0'/> <model type='virtio'/> <alias name='net0'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x0'/> </interface> <serial type='pty'> <source path='/dev/pts/0'/> <target type='isa-serial' port='0'> <model name='isa-serial'/> </target> <alias name='serial0'/> </serial> <console type='pty' tty='/dev/pts/0'> <source path='/dev/pts/0'/> <target type='serial' port='0'/> <alias name='serial0'/> </console> <channel type='unix'> <source mode='bind' path='/var/lib/libvirt/qemu/channel/target/domain-3-Windows 10/org.qemu.guest_agent.0'/> <target type='virtio' name='org.qemu.guest_agent.0' state='connected'/> <alias name='channel0'/> <address type='virtio-serial' controller='0' bus='0' port='1'/> </channel> <input type='mouse' bus='ps2'> <alias name='input0'/> </input> <input type='keyboard' bus='ps2'> <alias name='input1'/> </input> <hostdev mode='subsystem' type='pci' managed='yes'> <driver name='vfio'/> <source> <address domain='0x0000' bus='0x01' slot='0x00' function='0x0'/> </source> <alias name='hostdev0'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x05' function='0x0'/> </hostdev> <hostdev mode='subsystem' type='pci' managed='yes'> <driver name='vfio'/> <source> <address domain='0x0000' bus='0x02' slot='0x00' function='0x0'/> </source> <alias name='hostdev1'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x06' function='0x0'/> </hostdev> <hostdev mode='subsystem' type='pci' managed='yes'> <driver name='vfio'/> <source> <address domain='0x0000' bus='0x01' slot='0x00' function='0x1'/> </source> <alias name='hostdev2'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x08' function='0x0'/> </hostdev> <hostdev mode='subsystem' type='pci' managed='yes'> <driver name='vfio'/> <source> <address domain='0x0000' bus='0x02' slot='0x00' function='0x1'/> </source> <alias name='hostdev3'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x09' function='0x0'/> </hostdev> <hostdev mode='subsystem' type='usb' managed='no'> <source> <vendor id='0x046d'/> <product id='0x085b'/> <address bus='1' device='9'/> </source> <alias name='hostdev4'/> <address type='usb' bus='0' port='1'/> </hostdev> <hostdev mode='subsystem' type='usb' managed='no'> <source> <vendor id='0x046d'/> <product id='0xc083'/> <address bus='1' device='6'/> </source> <alias name='hostdev5'/> <address type='usb' bus='0' port='2'/> </hostdev> <hostdev mode='subsystem' type='usb' managed='no'> <source> <vendor id='0x046d'/> <product id='0xc337'/> <address bus='1' device='4'/> </source> <alias name='hostdev6'/> <address type='usb' bus='0' port='3'/> </hostdev> <hostdev mode='subsystem' type='usb' managed='no'> <source> <vendor id='0x0763'/> <product id='0x400c'/> <address bus='3' device='2'/> </source> <alias name='hostdev7'/> <address type='usb' bus='0' port='4'/> </hostdev> <hostdev mode='subsystem' type='usb' managed='no'> <source> <vendor id='0x1e71'/> <product id='0x170e'/> <address bus='1' device='3'/> </source> <alias name='hostdev8'/> <address type='usb' bus='0' port='5'/> </hostdev> <memballoon model='virtio'> <alias name='balloon0'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x0a' function='0x0'/> </memballoon> </devices> <seclabel type='dynamic' model='dac' relabel='yes'> <label>+0:+100</label> <imagelabel>+0:+100</imagelabel> </seclabel> </domain> Thank you! Edited June 26, 20188 yr by grantphillips
