September 7, 20188 yr Did some searches but never came across an answer. I get this line you see in the subject very often in my unraid logs. It is not a consistent time, though. Sometimes it's within minutes of each other, sometimes seconds. I feel this is a simple answer but strangely haven't found the solution yet.
May 11, 20233 yr I am having the same issue and it is a huge problem as it is my zigbee usb stick so all my zigbee devices stop working. looking for a fix: May 11 12:48:04 RAID kernel: usb 3-3: new full-speed USB device number 88 using xhci_hcd May 11 12:48:04 RAID kernel: usb 3-3: device descriptor read/64, error -71 May 11 12:48:04 RAID kernel: usb 3-3: device descriptor read/64, error -71 May 11 12:48:05 RAID kernel: usb 3-3: new full-speed USB device number 89 using xhci_hcd May 11 12:48:05 RAID kernel: usb 3-3: device descriptor read/64, error -71 May 11 12:48:05 RAID kernel: usb 3-3: device descriptor read/64, error -71 May 11 12:48:05 RAID kernel: usb usb3-port3: attempt power cycle May 11 12:48:05 RAID kernel: usb 3-3: new full-speed USB device number 90 using xhci_hcd May 11 12:48:05 RAID kernel: usb 3-3: Device not responding to setup address. May 11 12:48:06 RAID kernel: usb 3-3: Device not responding to setup address. May 11 12:48:06 RAID kernel: usb 3-3: device not accepting address 90, error -71 May 11 12:48:06 RAID kernel: usb 3-3: new full-speed USB device number 91 using xhci_hcd May 11 12:48:06 RAID kernel: usb 3-3: Device not responding to setup address. May 11 12:48:06 RAID kernel: usb 3-3: Device not responding to setup address. May 11 12:48:06 RAID kernel: usb 3-3: device not accepting address 91, error -71 May 11 12:48:06 RAID kernel: usb usb3-port3: unable to enumerate USB device
