September 13, 20187 yr Hello, as the topic states i have an hp z600 with two GPU installed: a gtx745 (primary video) and a gt710 Passthrough of the gtx745 OR gt710 is successful (i dumped video bios of both cards) if i plug only one vga card, instead when i try tu run a second VM i have the following log: 2018-09-13 08:44:27.205+0000: starting up libvirt version: 4.0.0, qemu version: 2.11.1, hostname: TowerLC_ALL=C PATH=/bin:/sbin:/usr/bin:/usr/sbin HOME=/ QEMU_AUDIO_DRV=none /usr/local/sbin/qemu -name 'guest=Windows 7,debug-threads=on' -S -object 'secret,id=masterKey0,format=raw,file=/var/lib/libvirt/qemu/domain-7-Windows 7/master-key.aes' -machine pc-q35-2.11,accel=kvm,usb=off,dump-guest-core=off,mem-merge=off -cpu host,hv_time,hv_relaxed,hv_vapic,hv_spinlocks=0x1fff,hv_vendor_id=none -m 8192 -realtime mlock=off -smp 2,sockets=1,cores=1,threads=2 -uuid 425eb42c-d39b-6572-4ab2-319ae5067c6e -display none -no-user-config -nodefaults -chardev 'socket,id=charmonitor,path=/var/lib/libvirt/qemu/domain-7-Windows 7/monitor.sock,server,nowait' -mon chardev=charmonitor,id=monitor,mode=control -rtc base=localtime -no-hpet -no-shutdown -boot strict=on -device pcie-root-port,port=0x8,chassis=1,id=pci.1,bus=pcie.0,multifunction=on,addr=0x1 -device pcie-root-port,port=0x9,chassis=2,id=pci.2,bus=pcie.0,addr=0x1.0x1 -device pcie-root-port,port=0xa,chassis=3,id=pci.3,bus=pcie.0,addr=0x1.0-0-0,bootindex=2 -drive file=/mnt/user/isos/virtio-win.iso,format=raw,if=none,id=drive-sata0-0-1,media=cdrom,readonly=on -device ide-cd,bus=ide.1,drive=drive-sata0-0-1,id=sata0-0-1 -netdev tap,fd=28,id=hostnet0,vhost=on,vhostfd=30 -device virtio-net-pci,netdev=hostnet0,id=net0,mac=52:54:00:22:f7:0c,bus=pci.1,addr=0x0 -chardev pty,id=charserial0 -device isa-serial,chardev=charserial0,id=serial0 -chardev 'socket,id=charchannel0,path=/var/lib/libvirt/qemu/channel/target/domain-7-Windows 7/org.qemu.guest_agent.0,server,nowait' -device virtserialport,bus=virtio-serial0.0,nr=1,chardev=charchannel0,id=channel0,name=org.qemu.guest_agent.0 -device vfio-pci,host=03:00.0,id=hostdev0,x-vga=on,bus=pci.4,addr=0x0,romfile=/bios/gt710.rom -device vfio-pci,host=03:00.1,id=hostdev1,bus=pci.5,addr=0x0 -device virtio-balloon-pci,id=balloon0,bus=pci.6,addr=0x0 -msg timestamp=on 2018-09-13 08:44:27.205+0000: Domain id=7 is tainted: high-privileges 2018-09-13 08:44:27.205+0000: Domain id=7 is tainted: host-cpu 2018-09-13T08:44:27.305553Z qemu-system-x86_64: -chardev pty,id=charserial0: char device redirected to /dev/pts/1 (label charserial0) 2018-09-13T08:44:31.107078Z qemu-system-x86_64: VFIO_MAP_DMA: -14 2018-09-13T08:44:31.107101Z qemu-system-x86_64: vfio_dma_map(0x1488b5061180, 0xf0000000, 0x2000000, 0x1486a6000000) = -14 (Bad address)qemu: hardware error: vfio: DMA mapping failed, unable to continueCPU #0: EAX=00000103 EBX=80040004 ECX=00000103 EDX=00000cfc ESI=00040000 EDI=00000000 EBP=7ffa9d10 ESP=00006d3c EIP=000ec542 EFL=00000046 [---Z-P-] CPL=0 II=0 A20=1 SMM=0 HLT=0 ES =0010 00000000 ffffffff 00c09300 DPL=0 DS [-WA] CS =0008 00000000 ffffffff 00c09b00 DPL=0 CS32 [-RA] SS =0010 00000000 ffffffff 00c09300 DPL=0 DS [-WA] DS =0010 00000000 ffffffff 00c09300 DPL=0 DS [-WA] FS =0010 00000000 ffffffff 00c09300 DPL=0 DS [-WA] GS =0010 00000000 ffffffff 00c09300 DPL=0 DS [-WA] LDT=0000 00000000 0000ffff 00008200 DPL=0 LDT TR =0000 00000000 0000ffff 00008b00 DPL=0 TSS32-busy GDT= 000f6140 00000037 IDT= 000f617e 00000000 CR0=00000011 CR2=00000000 CR3=00000000 CR4=00000000 DR0=0000000000000000 DR1=0000000000000000 DR2=0000000000000000 DR3=0000000000000000 DR6=00000000ffff0ff0 DR7=0000000000000400 EFER=0000000000000000 FCW=037f FSW=0000 [ST=0] FTW=00 MXCSR=00001f80 FPR0=0000000000000000 0000 FPR1=0000000000000000 0000 FPR2=0000000000000000 0000 FPR3=0000000000000000 0000 FPR4=0000000000000000 0000 FPR5=0000000000000000 0000 FPR6=0000000000000000 0000 FPR7=0000000000000000 0000 XMM00=00000000000000000000000000000000 XMM01=00000000000000000000000000000000 XMM02=00000000000000000000000000000000 XMM03=00000000000000000000000000000000 XMM04=00000000000000000000000000000000 XMM05=00000000000000000000000000000000 XMM06=00000000000000000000000000000000 XMM07=00000000000000000000000000000000 CPU #1: EAX=00000000 EBX=00000000 ECX=00000000 EDX=000206c2 ESI=00000000 EDI=00000000 EBP=00000000 ESP=00000000 EIP=0000fff0 EFL=00000002 [-------] CPL=0 II=0 A20=1 SMM=0 HLT=0 ES =0000 00000000 0000ffff 00009300 CS =f000 ffff0000 0000ffff 00009b00 SS =0000 00000000 0000ffff 00009300 DS =0000 00000000 0000ffff 00009300 FS =0000 00000000 0000ffff 00009300 GS =0000 00000000 0000ffff 00009300 LDT=0000 00000000 0000ffff 00008200 TR =0000 00000000 0000ffff 00008b00 GDT= 00000000 0000ffff IDT= 00000000 0000ffff CR0=60000010 CR2=00000000 CR3=00000000 CR4=00000000 DR0=0000000000000000 DR1=0000000000000000 DR2=0000000000000000 DR3=0000000000000000 DR6=00000000ffff0ff0 DR7=0000000000000400 EFER=0000000000000000 FCW=037f FSW=0000 [ST=0] FTW=00 MXCSR=00001f80 FPR0=0000000000000000 0000 FPR1=0000000000000000 0000 FPR2=0000000000000000 0000 FPR3=0000000000000000 0000 FPR4=0000000000000000 0000 FPR5=0000000000000000 0000 FPR6=0000000000000000 0000 FPR7=0000000000000000 0000 XMM00=00000000000000000000000000000000 XMM01=00000000000000000000000000000000 XMM02=00000000000000000000000000000000 XMM03=00000000000000000000000000000000 XMM04=00000000000000000000000000000000 XMM05=00000000000000000000000000000000 XMM06=00000000000000000000000000000000 XMM07=00000000000000000000000000000000 2018-09-13 08:44:32.513+0000: shutting down, reason=crashed This is my boot config default menu.c32 menu title Lime Technology, Inc. prompt 0 timeout 50 label unRAID OS menu default kernel /bzimage append pci-stub.ids=10de:128b,10de:0e0f,1106:3483 vfio_iommu_type1.allow_unsafe_interrupts=1 initrd=/bzroot label unRAID OS GUI Mode kernel /bzimage append initrd=/bzroot,/bzroot-gui label unRAID OS Safe Mode (no plugins, no GUI) kernel /bzimage append initrd=/bzroot unraidsafemode label unRAID OS GUI Safe Mode (no plugins) kernel /bzimage append initrd=/bzroot,/bzroot-gui unraidsafemode label Memtest86+ kernel /memtest and this is the pci configuration: IOMMU group 0: [8086:3406] 00:00.0 Host bridge: Intel Corporation 5520 I/O Hub to ESI Port (rev 13) IOMMU group 1: [8086:3408] 00:01.0 PCI bridge: Intel Corporation 5520/5500/X58 I/O Hub PCI Express Root Port 1 (rev 13) IOMMU group 2: [8086:340a] 00:03.0 PCI bridge: Intel Corporation 5520/5500/X58 I/O Hub PCI Express Root Port 3 (rev 13) IOMMU group 3: [8086:340e] 00:07.0 PCI bridge: Intel Corporation 5520/5500/X58 I/O Hub PCI Express Root Port 7 (rev 13) IOMMU group 4: [8086:3425] 00:10.0 PIC: Intel Corporation 7500/5520/5500/X58 Physical and Link Layer Registers Port 0 (rev 13) [8086:3426] 00:10.1 PIC: Intel Corporation 7500/5520/5500/X58 Routing and Protocol Layer Registers Port 0 (rev 13) IOMMU group 5: [8086:3427] 00:11.0 PIC: Intel Corporation 7500/5520/5500 Physical and Link Layer Registers Port 1 (rev 13) [8086:3428] 00:11.1 PIC: Intel Corporation 7500/5520/5500 Routing & Protocol Layer Register Port 1 (rev 13) IOMMU group 6: [8086:342e] 00:14.0 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub System Management Registers (rev 13) [8086:3422] 00:14.1 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub GPIO and Scratch Pad Registers (rev 13) [8086:3423] 00:14.2 PIC: Intel Corporation 7500/5520/5500/X58 I/O Hub Control Status and RAS Registers (rev 13) IOMMU group 7: [8086:342f] 00:15.0 PIC: Intel Corporation 7500/5520/5500/X58 Trusted Execution Technology Registers (rev 13) IOMMU group 8: [8086:3a37] 00:1a.0 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #4 [8086:3a38] 00:1a.1 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #5 [8086:3a39] 00:1a.2 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #6 [8086:3a3c] 00:1a.7 USB controller: Intel Corporation 82801JI (ICH10 Family) USB2 EHCI Controller #2 IOMMU group 9: [8086:3a3e] 00:1b.0 Audio device: Intel Corporation 82801JI (ICH10 Family) HD Audio Controller IOMMU group 10: [8086:3a40] 00:1c.0 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 1 [8086:3a4a] 00:1c.5 PCI bridge: Intel Corporation 82801JI (ICH10 Family) PCI Express Root Port 6 [14e4:1684] 01:00.0 Ethernet controller: Broadcom Limited NetXtreme BCM5764M Gigabit Ethernet PCIe (rev 10) IOMMU group 11: [8086:3a34] 00:1d.0 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #1 [8086:3a35] 00:1d.1 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #2 [8086:3a36] 00:1d.2 USB controller: Intel Corporation 82801JI (ICH10 Family) USB UHCI Controller #3 [8086:3a3a] 00:1d.7 USB controller: Intel Corporation 82801JI (ICH10 Family) USB2 EHCI Controller #1 IOMMU group 12: [8086:244e] 00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev 90) [11c1:5811] 37:05.0 FireWire (IEEE 1394): LSI Corporation FW322/323 [TrueFire] 1394a Controller (rev 70) IOMMU group 13: [8086:3a16] 00:1f.0 ISA bridge: Intel Corporation 82801JIR (ICH10R) LPC Interface Controller [8086:2822] 00:1f.2 RAID bus controller: Intel Corporation SATA Controller [RAID mode] IOMMU group 14: [10de:128b] 03:00.0 VGA compatible controller: NVIDIA Corporation GK208B [GeForce GT 710] (rev a1) [10de:0e0f] 03:00.1 Audio device: NVIDIA Corporation GK208 HDMI/DP Audio Controller (rev a1) IOMMU group 15: [10de:1382] 28:00.0 VGA compatible controller: NVIDIA Corporation GM107 [GeForce GTX 745] (rev a2) [10de:0fbc] 28:00.1 Audio device: NVIDIA Corporation Device 0fbc (rev a1) IOMMU group 16: [8086:2c70] 3f:00.0 Host bridge: Intel Corporation Xeon 5600 Series QuickPath Architecture Generic Non-core Registers (rev 02) [8086:2d81] 3f:00.1 Host bridge: Intel Corporation Xeon 5600 Series QuickPath Architecture System Address Decoder (rev 02) IOMMU group 17: [8086:2d90] 3f:02.0 Host bridge: Intel Corporation Xeon 5600 Series QPI Link 0 (rev 02) [8086:2d91] 3f:02.1 Host bridge: Intel Corporation Xeon 5600 Series QPI Physical 0 (rev 02) [8086:2d92] 3f:02.2 Host bridge: Intel Corporation Xeon 5600 Series Mirror Port Link 0 (rev 02) [8086:2d93] 3f:02.3 Host bridge: Intel Corporation Xeon 5600 Series Mirror Port Link 1 (rev 02) [8086:2d94] 3f:02.4 Host bridge: Intel Corporation Xeon 5600 Series QPI Link 1 (rev 02) [8086:2d95] 3f:02.5 Host bridge: Intel Corporation Xeon 5600 Series QPI Physical 1 (rev 02) IOMMU group 18: [8086:2d98] 3f:03.0 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Registers (rev 02) [8086:2d99] 3f:03.1 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Target Address Decoder (rev 02) [8086:2d9a] 3f:03.2 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller RAS Registers (rev 02) [8086:2d9c] 3f:03.4 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Test Registers (rev 02) IOMMU group 19: [8086:2da0] 3f:04.0 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 0 Control (rev 02) [8086:2da1] 3f:04.1 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 0 Address (rev 02) [8086:2da2] 3f:04.2 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 0 Rank (rev 02) [8086:2da3] 3f:04.3 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 0 Thermal Control (rev 02) IOMMU group 20: [8086:2da8] 3f:05.0 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 1 Control (rev 02) [8086:2da9] 3f:05.1 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 1 Address (rev 02) [8086:2daa] 3f:05.2 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 1 Rank (rev 02) [8086:2dab] 3f:05.3 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 1 Thermal Control (rev 02) IOMMU group 21: [8086:2db0] 3f:06.0 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 2 Control (rev 02) [8086:2db1] 3f:06.1 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 2 Address (rev 02) [8086:2db2] 3f:06.2 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 2 Rank (rev 02) [8086:2db3] 3f:06.3 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 2 Thermal Control (rev 02) IOMMU group 22: [8086:2c70] 3e:00.0 Host bridge: Intel Corporation Xeon 5600 Series QuickPath Architecture Generic Non-core Registers (rev 02) [8086:2d81] 3e:00.1 Host bridge: Intel Corporation Xeon 5600 Series QuickPath Architecture System Address Decoder (rev 02) IOMMU group 23: [8086:2d90] 3e:02.0 Host bridge: Intel Corporation Xeon 5600 Series QPI Link 0 (rev 02) [8086:2d91] 3e:02.1 Host bridge: Intel Corporation Xeon 5600 Series QPI Physical 0 (rev 02) [8086:2d92] 3e:02.2 Host bridge: Intel Corporation Xeon 5600 Series Mirror Port Link 0 (rev 02) [8086:2d93] 3e:02.3 Host bridge: Intel Corporation Xeon 5600 Series Mirror Port Link 1 (rev 02) [8086:2d94] 3e:02.4 Host bridge: Intel Corporation Xeon 5600 Series QPI Link 1 (rev 02) [8086:2d95] 3e:02.5 Host bridge: Intel Corporation Xeon 5600 Series QPI Physical 1 (rev 02) IOMMU group 24: [8086:2d98] 3e:03.0 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Registers (rev 02) [8086:2d99] 3e:03.1 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Target Address Decoder (rev 02) [8086:2d9a] 3e:03.2 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller RAS Registers (rev 02) [8086:2d9c] 3e:03.4 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Test Registers (rev 02) IOMMU group 25: [8086:2da0] 3e:04.0 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 0 Control (rev 02) [8086:2da1] 3e:04.1 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 0 Address (rev 02) [8086:2da2] 3e:04.2 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 0 Rank (rev 02) [8086:2da3] 3e:04.3 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 0 Thermal Control (rev 02) IOMMU group 26: [8086:2da8] 3e:05.0 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 1 Control (rev 02) [8086:2da9] 3e:05.1 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 1 Address (rev 02) [8086:2daa] 3e:05.2 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 1 Rank (rev 02) [8086:2dab] 3e:05.3 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 1 Thermal Control (rev 02) IOMMU group 27: [8086:2db0] 3e:06.0 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 2 Control (rev 02) [8086:2db1] 3e:06.1 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 2 Address (rev 02) [8086:2db2] 3e:06.2 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 2 Rank (rev 02) [8086:2db3] 3e:06.3 Host bridge: Intel Corporation Xeon 5600 Series Integrated Memory Controller Channel 2 Thermal Control (rev 02) Please help me, i'm clueless.... Thank you
September 13, 20187 yr A. Please attach diagnostics. B. Did you bother to read your post to see how hard to read it is? C. "Passthrough of the gtx745 OR gt710 is successful ... if i plug only one vga card, instead when i try tu run a second VM" <-- are you trying to run 2 VM with the same VGA? both VM, each with different VGA? running a 2nd VM with a single VGA plugged in?
September 13, 20187 yr Author A. Where? B. Sorry C. I am trying to run 2 VM each with one VGA. If i remove phisically one vga, the othe one is passed correctly to VM
September 13, 20187 yr 5 minutes ago, FdpZ said: A. Where? B. Sorry C. I am trying to run 2 VM each with one VGA. If i remove phisically one vga, the othe one is passed correctly to VM Tools -> Diagnostics -> download the full zip and attach here.
September 13, 20187 yr Your diagnostics do not contain your qemu (VM configs) nor the errors so there's nothing to use. Set your VMs up. Make sure you can replicate the issues. I.e. can boot 1 VM separately but have error when booting both at the same time. Then run diagnostics and attach zip file.
September 22, 20187 yr I run a z400 and z420 and haven't seen this issue before. But I've also not setup a windows 7 vm. To troubleshoot, try using the card in a windows 10 vm something else to determine if it is a problem with the vm os or server os/hardware related. When you do, try it as the only vm running, and then with both running.
