Read errors on drive after power failure
Hey all, I have a disk reporting some read errors after a power outage. Not sure what happened exactly since I do have a UPS but it didn't seem to help anything. I'll be investigating that separately. See attached diagnostics.
Is this something I just keep an eye on if its increments or is this an issue?
smartctl 6.6 2017-11-05 r4594 [x86_64-linux-4.14.49-unRAID] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family:     Western Digital Red
Device Model:     WDC WD40EFRX-68WT0N0
Serial Number:    WD-WCC4E3USPU9A
LU WWN Device Id: 5 0014ee 20dcc0aef
Firmware Version: 82.00A82
User Capacity:    4,000,787,030,016 bytes [4.00 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    5400 rpm
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Sat Sep 29 16:03:05 2018 EDT
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Unavailable
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Unavailable
ATA Security is:  Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x00)	Offline data collection activity
					was never started.
					Auto Offline Data Collection: Disabled.
Self-test execution status:      (  17)	The self-test routine was aborted by
					the host.
Total time to complete Offline
data collection: 		(52980) seconds.
capabilities: 			 (0x7b) SMART execute Offline immediate.
					Auto Offline data collection on/off support.
					Suspend Offline collection upon new
					command.
					Offline surface scan supported.
					Self-test supported.
					Conveyance Self-test supported.
					Selective Self-test supported.
SMART capabilities:            (0x0003)	Saves SMART data before entering
					power-saving mode.
					Supports SMART auto save timer.
Error logging capability:        (0x01)	Error logging supported.
					General Purpose Logging supported.
Short self-test routine
recommended polling time: 	 (   2) minutes.
Extended self-test routine
recommended polling time: 	 ( 530) minutes.
Conveyance self-test routine
recommended polling time: 	 (   5) minutes.
SCT capabilities: 	       (0x703d)	SCT Status supported.
					SCT Error Recovery Control supported.
					SCT Feature Control supported.
					SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     POSR-K   200   200   051    -    68
  3 Spin_Up_Time            POS--K   182   178   021    -    7858
  4 Start_Stop_Count        -O--CK   097   097   000    -    3209
  5 Reallocated_Sector_Ct   PO--CK   200   200   140    -    0
  7 Seek_Error_Rate         -OSR-K   100   253   000    -    0
  9 Power_On_Hours          -O--CK   079   079   000    -    15596
 10 Spin_Retry_Count        -O--CK   100   100   000    -    0
 11 Calibration_Retry_Count -O--CK   100   253   000    -    0
 12 Power_Cycle_Count       -O--CK   100   100   000    -    35
192 Power-Off_Retract_Count -O--CK   200   200   000    -    9
193 Load_Cycle_Count        -O--CK   193   193   000    -    22750
194 Temperature_Celsius     -O---K   116   113   000    -    36
196 Reallocated_Event_Count -O--CK   200   200   000    -    0
197 Current_Pending_Sector  -O--CK   200   200   000    -    0
198 Offline_Uncorrectable   ----CK   100   253   000    -    0
199 UDMA_CRC_Error_Count    -O--CK   200   200   000    -    0
200 Multi_Zone_Error_Rate   ---R--   100   253   000    -    0
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      5  Comprehensive SMART error log
0x03       GPL     R/O      6  Ext. Comprehensive SMART error log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x09           SL  R/W      1  Selective self-test log
0x10       GPL     R/O      1  NCQ Command Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x21       GPL     R/O      1  Write stream error log
0x22       GPL     R/O      1  Read stream error log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xa0-0xa7  GPL,SL  VS      16  Device vendor specific log
0xa8-0xb6  GPL,SL  VS       1  Device vendor specific log
0xb7       GPL,SL  VS      39  Device vendor specific log
0xbd       GPL,SL  VS       1  Device vendor specific log
0xc0       GPL,SL  VS       1  Device vendor specific log
0xc1       GPL     VS      93  Device vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
Device Error Count: 6
	CR     = Command Register
	FEATR  = Features Register
	COUNT  = Count (was: Sector Count) Register
	LBA_48 = Upper bytes of LBA High/Mid/Low Registers ]  ATA-8
	LH     = LBA High (was: Cylinder High) Register    ]   LBA
	LM     = LBA Mid (was: Cylinder Low) Register      ] Register
	LL     = LBA Low (was: Sector Number) Register     ]
	DV     = Device (was: Device/Head) Register
	DC     = Device Control Register
	ER     = Error register
	ST     = Status register
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 6 [5] occurred at disk power-on lifetime: 15594 hours (649 days + 18 hours)
  When the command that caused the error occurred, the device was active or idle.
  After command completion occurred, registers were:
  ER -- ST COUNT  LBA_48  LH LM LL DV DC
  40 -- 51 05 40 00 00 01 63 58 98 e0 00  Error: UNC 1344 sectors at LBA = 0x01635898 = 23287960
  Commands leading to the command that caused the error were:
  CR FEATR COUNT  LBA_48  LH LM LL DV DC  Powered_Up_Time  Command/Feature_Name
  25 00 00 05 40 00 00 01 63 58 98 e0 08     00:31:48.994  READ DMA EXT
  25 00 00 01 90 00 00 01 63 57 08 e0 08     00:31:48.602  READ DMA EXT
  25 00 00 05 40 00 00 01 63 51 c8 e0 08     00:31:48.599  READ DMA EXT
  35 00 00 01 08 00 00 01 63 4a 98 e0 08     00:31:48.598  WRITE DMA EXT
  25 00 00 04 28 00 00 01 63 4d a0 e0 08     00:31:48.595  READ DMA EXT
Error 5 [4] occurred at disk power-on lifetime: 15594 hours (649 days + 18 hours)
  40 -- 51 02 00 00 00 01 63 4a 98 e0 00  Error: UNC 512 sectors at LBA = 0x01634a98 = 23284376
  25 00 00 02 00 00 00 01 63 49 a0 e0 08     00:31:44.254  READ DMA EXT
  c8 00 00 00 c0 00 00 01 63 48 e0 e1 08     00:31:44.230  READ DMA
  25 00 00 05 40 00 00 01 63 43 a0 e0 08     00:31:44.229  READ DMA EXT
  25 00 00 02 00 00 00 01 63 41 a0 e0 08     00:31:44.227  READ DMA EXT
  25 00 00 02 00 00 00 01 63 3f a0 e0 08     00:31:44.226  READ DMA EXT
Error 4 [3] occurred at disk power-on lifetime: 15594 hours (649 days + 18 hours)
  40 -- 51 05 40 00 00 01 63 1e f0 e0 00  Error: UNC 1344 sectors at LBA = 0x01631ef0 = 23273200
  25 00 00 05 40 00 00 01 63 1a 78 e0 08     00:31:40.196  READ DMA EXT
  25 00 00 02 00 00 00 01 63 18 78 e0 08     00:31:40.171  READ DMA EXT
  25 00 00 00 08 00 01 ba 14 17 00 e0 08     00:31:40.150  READ DMA EXT
  25 00 00 01 a8 00 00 01 63 16 d0 e0 08     00:31:40.149  READ DMA EXT
  25 00 00 05 40 00 00 01 63 11 90 e0 08     00:31:40.129  READ DMA EXT
Error 3 [2] occurred at disk power-on lifetime: 15593 hours (649 days + 17 hours)
  40 -- 51 05 40 00 00 01 63 58 50 e0 00  Error: UNC 1344 sectors at LBA = 0x01635850 = 23287888
  25 00 00 05 40 00 00 01 63 56 08 e0 08     00:13:09.388  READ DMA EXT
  35 00 00 01 b8 00 00 01 63 4a 50 e0 08     00:13:09.387  WRITE DMA EXT
  25 00 00 00 08 00 00 bf fc 07 50 e0 08     00:13:09.372  READ DMA EXT
  25 00 00 02 c0 00 00 01 63 53 48 e0 08     00:13:09.370  READ DMA EXT
  25 00 00 05 40 00 00 01 63 4e 08 e0 08     00:13:09.367  READ DMA EXT
Error 2 [1] occurred at disk power-on lifetime: 15593 hours (649 days + 17 hours)
  40 -- 51 02 00 00 00 01 63 4a 50 e0 00  Error: UNC 512 sectors at LBA = 0x01634a50 = 23284304
  25 00 00 02 00 00 00 01 63 4a 08 e0 08     00:13:05.412  READ DMA EXT
  25 00 00 02 00 00 00 01 63 48 08 e0 08     00:13:05.411  READ DMA EXT
  25 00 00 02 00 00 00 01 63 46 08 e0 08     00:13:05.410  READ DMA EXT
  25 00 00 02 00 00 00 01 63 44 08 e0 08     00:13:05.409  READ DMA EXT
  25 00 00 01 58 00 00 01 63 42 b0 e0 08     00:13:05.384  READ DMA EXT
Error 1 [0] occurred at disk power-on lifetime: 15593 hours (649 days + 17 hours)
  40 -- 51 02 00 00 00 01 63 1e a8 e0 00  Error: UNC 512 sectors at LBA = 0x01631ea8 = 23273128
  25 00 00 02 00 00 00 01 63 1e 08 e0 08     00:13:01.826  READ DMA EXT
  25 00 00 02 00 00 00 01 63 1c 08 e0 08     00:13:01.825  READ DMA EXT
  25 00 00 02 c0 00 00 01 63 19 48 e0 08     00:13:01.821  READ DMA EXT
  25 00 00 05 40 00 00 01 63 14 08 e0 08     00:13:01.817  READ DMA EXT
  25 00 00 02 00 00 00 01 63 12 08 e0 08     00:13:01.816  READ DMA EXT
SMART Extended Self-test Log Version: 1 (1 sectors)
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline       Aborted by host               10%     15596         -
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
SCT Status Version:                  3
SCT Version (vendor specific):       258 (0x0102)
SCT Support Level:                   1
Device State:                        Active (0)
Current Temperature:                    36 Celsius
Power Cycle Min/Max Temperature:     29/36 Celsius
Lifetime    Min/Max Temperature:     19/39 Celsius
Under/Over Temperature Limit Count:   0/0
Vendor specific:
01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version:     2
Temperature Sampling Period:         1 minute
Temperature Logging Interval:        1 minute
Min/Max recommended Temperature:      0/60 Celsius
Min/Max Temperature Limit:           -41/85 Celsius
Temperature History Size (Index):    478 (286)
Index    Estimated Time   Temperature Celsius
 287    2018-09-29 08:06    27  ********
 ...    ..( 26 skipped).    ..  ********
 314    2018-09-29 08:33    27  ********
 315    2018-09-29 08:34     ?  -
 316    2018-09-29 08:35    27  ********
 317    2018-09-29 08:36    27  ********
 318    2018-09-29 08:37    28  *********
 319    2018-09-29 08:38     ?  -
 320    2018-09-29 08:39    29  **********
 ...    ..(  4 skipped).    ..  **********
 325    2018-09-29 08:44    29  **********
 326    2018-09-29 08:45    30  ***********
 ...    ..(  2 skipped).    ..  ***********
 329    2018-09-29 08:48    30  ***********
 330    2018-09-29 08:49    31  ************
 331    2018-09-29 08:50    31  ************
 332    2018-09-29 08:51    31  ************
 333    2018-09-29 08:52    32  *************
 ...    ..( 11 skipped).    ..  *************
 345    2018-09-29 09:04    32  *************
 346    2018-09-29 09:05    33  **************
 ...    ..(  6 skipped).    ..  **************
 353    2018-09-29 09:12    33  **************
 354    2018-09-29 09:13    34  ***************
 ...    ..( 12 skipped).    ..  ***************
 367    2018-09-29 09:26    34  ***************
 368    2018-09-29 09:27    35  ****************
 ...    ..( 30 skipped).    ..  ****************
 399    2018-09-29 09:58    35  ****************
 400    2018-09-29 09:59    36  *****************
 ...    ..(107 skipped).    ..  *****************
  30    2018-09-29 11:47    36  *****************
  31    2018-09-29 11:48    29  **********
  32    2018-09-29 11:49    29  **********
  33    2018-09-29 11:50    29  **********
  34    2018-09-29 11:51     ?  -
  35    2018-09-29 11:52    29  **********
 ...    ..( 13 skipped).    ..  **********
  49    2018-09-29 12:06    29  **********
  50    2018-09-29 12:07    30  ***********
  63    2018-09-29 12:20    30  ***********
  64    2018-09-29 12:21    31  ************
 ...    ..( 26 skipped).    ..  ************
  91    2018-09-29 12:48    31  ************
  92    2018-09-29 12:49    32  *************
 ...    ..(  5 skipped).    ..  *************
  98    2018-09-29 12:55    32  *************
  99    2018-09-29 12:56    31  ************
 ...    ..(  2 skipped).    ..  ************
 102    2018-09-29 12:59    31  ************
 103    2018-09-29 13:00    30  ***********
 110    2018-09-29 13:07    30  ***********
 111    2018-09-29 13:08    29  **********
 ...    ..( 15 skipped).    ..  **********
 127    2018-09-29 13:24    29  **********
 128    2018-09-29 13:25    28  *********
 ...    ..( 22 skipped).    ..  *********
 151    2018-09-29 13:48    28  *********
 152    2018-09-29 13:49    27  ********
 ...    ..(133 skipped).    ..  ********
 286    2018-09-29 16:03    27  ********
SCT Error Recovery Control:
           Read:     70 (7.0 seconds)
          Write:     70 (7.0 seconds)
Device Statistics (GP/SMART Log 0x04) not supported
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x0001  2            0  Command failed due to ICRC error
0x0002  2            0  R_ERR response for data FIS
0x0003  2            0  R_ERR response for device-to-host data FIS
0x0004  2            0  R_ERR response for host-to-device data FIS
0x0005  2            0  R_ERR response for non-data FIS
0x0006  2            0  R_ERR response for device-to-host non-data FIS
0x0007  2            0  R_ERR response for host-to-device non-data FIS
0x0008  2            0  Device-to-host non-data FIS retries
0x0009  2            9  Transition from drive PhyRdy to drive PhyNRdy
0x000a  2            9  Device-to-host register FISes sent due to a COMRESET
0x000b  2            0  CRC errors within host-to-device FIS
0x000f  2            0  R_ERR response for host-to-device data FIS, CRC
0x0012  2            0  R_ERR response for host-to-device non-data FIS, CRC
0x8000  4        11497  Vendor specific
tower-diagnostics-20180929-1333 (1).zip
Edited by drawde
It's a disk problem, you can run an extended SMART test, if it fails replace now, if it passes it might be OK to use for a while more, but it's likely on borrowed time, and keep an eye on this attribute:
Ideally it should be zero, anything above low double digits is usually a very bad sign.
I tried to run an extended SMART report and it got stuck on 90% for like forever. It's running a parity check, not sure if it has anything to do with it.
The drive is still under warranty, is it possible to RMA?
You shouldn't do both things at the same time, in practice a parity check is as good a test as the extended SMART test, just make sure it's running a non correcting check.
Yes, just report the problem as read errors (UNC at LBA on the SMART report)
Okay so it sounds l like after the parity check, run an extended SMART test. If it passes it should be OK as long as the read errors don't increment? Or should I RMA regardless?
One or the other is enough for now, if there are read errors during the parity check it needs to be replaced now.
In my experience once they start getting those high double digit raw read errors it's just a matter of time until it fails again, on the other hand, RMA refurnished disks are a crapshoot, so you decide, unless you can trade it with a new one, then go for it.
