October 13, 20187 yr So my UPS decided to tell me to replace battery at the worst possible time: I'm re-building and doing parity check after installing a larger drive. It woudl be fairly loud in my bedroom for the next 30+ hours... Easiest would be to shut the noise on my APC Back-UPS Power-Saving ES 8, but the command upscmd apc beeper.disable I found online doesn't work, and I can't install upscmd with apt-get install either (what happened to apt-get?). There doesn't seem to be an option for this in the unraid control center, either. Option B is to stop the re-build, and install a new battery. Can I safely stop the re-build? I have the original data on another fully functioning HDD.
October 13, 20187 yr Community Expert Just now, Ulvan said: Can I safely stop the re-build? Yes, but it will re-start from the beginning at next boot.
October 13, 20187 yr Author 3 hours ago, johnnie.black said: Yes, but it will re-start from the beginning at next boot. Yeah, I figured. I'd rather have that than try to sleep through this ruckus Thanks! Edited October 13, 20187 yr by Ulvan
October 14, 20187 yr 20 hours ago, Ulvan said: I can't install upscmd with apt-get install either (what happened to apt-get?). Unraid is built on slackware linux, which doesn't use apt-get. Not sure what you mean by "what happened", it has never been a part of unraid. It's possible you may be able to control the alarm with apctest, which is part of the apcupsd package that stock unraid uses to manage and monitor the UPS.
October 14, 20187 yr So my UPS decided to tell me to replace battery at the worst possible time: I'm re-building and doing parity check after installing a larger drive. It woudl be fairly loud in my bedroom for the next 30+ hours... Easiest would be to shut the noise on my APC Back-UPS Power-Saving ES 8, but the command upscmd apc beeper.disable I found online doesn't work, and I can't install upscmd with apt-get install either (what happened to apt-get?). There doesn't seem to be an option for this in the unraid control center, either. Option B is to stop the re-build, and install a new battery. Can I safely stop the re-build? I have the original data on another fully functioning HDD.Is the battery not hot swappable?Sent from my iPhone using Tapatalk Pro
October 14, 20187 yr Author 1 hour ago, spl147 said: Is the battery not hot swappable? Sent from my iPhone using Tapatalk Pro Don't think it is in the mid-range consumer model I have. Edited October 14, 20187 yr by Ulvan
October 14, 20187 yr Don't think it is in the mid-range consumer model I have.Ah......Sent from my iPhone Xs Max using Tapatalk Pro
