December 15, 20187 yr Our power went out while we were streaming from our Unraid server. When power came back hours later we can connect to Unreal and then the connection will drop and then reconnect a few minutes later. The cycle keeps going... I checked the USB stick and it had an error. After I fixed it there was no change. Took awhile but I managed to get a diagnostics file. (attached) Edit - Can't stay connected long enough to grab an undated file yet. Still trying Edited December 15, 20187 yr by Spudzspot wrong name, wrong file
December 15, 20187 yr Community Expert Try using the Console. After logging in, type diagnostics on the Command Line. That will write the Diagnostics file to the logs folder/directory on the flash drive. Shut the server down at that point, pull the drive and upload the file from your PC.
December 16, 20187 yr Author Thanks for the help! After absolutely no action on my part it reverted to proper operation after approx. 12 hours and is working flawlessly.
December 16, 20187 yr just btw, you can buy a UPS for <50€. It already helped me servival times... if power loss, it tells unraid to clean shutdown, when power comes back, the server turns itself on again... ^^
December 16, 20187 yr 8 minutes ago, nuhll said: just btw, you can buy a UPS for <50€. It already helped me servival times... if power loss, it tells unraid to clean shutdown, when power comes back, the server turns itself on again... ^^ This! It will prevent a power surge, component damage, keep you going and won't consume any extra electricity. Worthwhile investment!
December 18, 20187 yr Community Expert On 12/16/2018 at 6:28 AM, nuhll said: the server turns itself on again... ^^ This is a BIOS setting. Most of the time the BIOS (if the option is available) defaults to not automatically restarting the system up on power application. You also have to program the UPS to shutdown power conversion after the server shutdown is finished and not to supply power until AC power is restored. Edited December 18, 20187 yr by Frank1940
