January 24, 20197 yr As title suggests I have a LAN transfer speed issue I cannot diagnose and fix. I know it is related to this Windows machine though. It is not UnRaid, and it is not the network. This PC used to saturate my 1 Gbps link during writes to Unraid. Now it hovers around 50-60 MB/s. At this point other than reloading a fresh install of Windows I don't know what to do. My googlefu is at its end. Any suggestions super welcome Other PCs plugged into the same port will saturate the 1 Gbps link writing to UnRaid. 110-112 MB/s solid. (this PC used to also) Been wanting to create a port channel for this PC anyway since my UnRaid server has a 4 Gbps channel-group So now this PC has 5 brand new CAT6 cables creating a 5 Gbps channel-group to my Cisco 3750X switch. Then the UnRaid server has a 4 Gbps channel-group also to the 3750X. The PC is no slouch. Windows 10 Pro, 64 bit. i7 5820k 6 core / 12 thread CPU, 32 GB DDR4. I've reloaded drivers, I've now added an additional NIC. Other than doing a fresh install of Windows I'm at the end of my rope. I don't know what to do. Any suggestions? Thanks, Andrew
January 24, 20197 yr Author SOB It was my firewall. I could SWEAR I had tried turning it off in the past to troubleshoot this issue. I turned off "Intrusion Detection Systems" and now I'm back to 112 MB/s. Would have thought I would be closer to my drive speed now that I have a 5gbps link but oh well. Im happy for now
January 24, 20197 yr 8 hours ago, allischalmersman said: back to 112 MB/s. Would have thought I would be closer to my drive speed now that I have a 5gbps link Pretty sure SMB transfers aren't multi channel, so to saturate the link you would need multiple diverse connections. I bet if you opened a FTP transfer and NFS at the same time you could get decent rates on all of them simultaneously.
January 24, 20197 yr Author Pretty sure SMB transfers aren't multi channel, so to saturate the link you would need multiple diverse connections. I bet if you opened a FTP transfer and NFS at the same time you could get decent rates on all of them simultaneously.I did some quick reading before bed last night and yeah what you say is exactly what I read. Basically I created a multi-lane highway but did not increase the speed for one car LOLSent from my SM-G965U using Tapatalk
