ikosa Posted March 1, 2019 Share Posted March 1, 2019 Suddenly i wake up with 2 disk read errors (1 is disabled) and parity check errors. Can anyone help with the prosedure what is the right thing to do? tower-diagnostics-20190301-1202.zip Link to comment
JorgeB Posted March 1, 2019 Share Posted March 1, 2019 Disabled disk dropped offline, you'll need to reboot to get a SMART report, but it looks like the typical SASLP problem. Link to comment
ikosa Posted March 1, 2019 Author Share Posted March 1, 2019 9 hours ago, johnnie.black said: Disabled disk dropped offline, you'll need to reboot to get a SMART report, but it looks like the typical SASLP problem. I attached the diags arter restart. tower-diagnostics-20190301-2225.zip Link to comment
JorgeB Posted March 1, 2019 Share Posted March 1, 2019 Disk looks fine, and emulated disk is mounting so you can rebuild on top, though rebuilding to a new/spare disk is always safer in case something goes wrong. You should also consider replacing the SASLP with an LSI, sooner rather then later, or this will most likely happen again. Link to comment
