March 4, 20197 yr Hello! After upgrading to patch 6.6.7 the Fix Common Problems plug in began to become unresponsive and the following information showed in the system log. Is there a way to fix this issue? Thanks! Mar 4 08:20:32 Kronos root: Fix Common Problems Version 2019.02.18 Mar 4 08:20:58 Kronos root: Fix Common Problems: Warning: Deprecated plugin ca.cleanup.appdata.plg ** Ignored Mar 4 08:22:32 Kronos nginx: 2019/03/04 08:22:32 [error] 10013#10013: *692 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 192.168.0.171, server: , request: "POST /plugins/fix.common.problems/include/fixExec.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock", host: "192.168.0.185", referrer: "http://192.168.0.185/Settings/FixProblems" Mar 4 08:22:47 Kronos root: Fix Common Problems Version 2019.02.18 Mar 4 08:23:14 Kronos root: Fix Common Problems: Warning: Deprecated plugin ca.cleanup.appdata.plg ** Ignored Mar 4 08:24:11 Kronos root: Fix Common Problems: Warning: dynamix.system.stats.plg Not Compatible with unRaid version 6.6.7 Mar 4 08:24:47 Kronos nginx: 2019/03/04 08:24:47 [error] 10013#10013: *872 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 192.168.0.171, server: , request: "POST /plugins/fix.common.problems/include/fixExec.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock", host: "192.168.0.185", referrer: "http://192.168.0.185/Settings/FixProblems" Mar 4 08:26:24 Kronos root: Fix Common Problems: Warning: dynamix.system.stats.plg Not Compatible with unRaid version 6.6.7 Mar 4 08:51:19 Kronos root: Fix Common Problems Version 2019.02.18 Mar 4 08:51:44 Kronos root: Fix Common Problems: Warning: Deprecated plugin ca.cleanup.appdata.plg ** Ignored Mar 4 08:53:19 Kronos nginx: 2019/03/04 08:53:19 [error] 10013#10013: *6635 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 192.168.0.171, server: , request: "POST /plugins/fix.common.problems/include/fixExec.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/php5-fpm.sock", host: "192.168.0.185", referrer: "http://192.168.0.185/Settings/FixProblems" Mar 4 08:54:55 Kronos root: Fix Common Problems: Warning: dynamix.system.stats.plg Not Compatible with unRaid version 6.6.7
