Help for passing through a device
On some boots of my unraid system, when I go to start my win10 VM I get the following error, this seems to cause both sound cards (nvidia attached to GPU, or the onboard) to not get passed through with it
2019-04-22T18:57:28.816539Z qemu-system-x86_64: vfio: Cannot reset device 0000:0b:00.3, depends on group 21 which is not owned.
Cant seem to see it in the gui anywhere to pass it through too, but not sure how to do it with the XML, any pointers?
Slight side note, I also seem to get crappy performance (144fps somtimes, but drops all over down to 60 etc) from my GPU, its a 1080ti and I'm giving it 8 cores matching pairs from my 2700x, but my old setup with a 4690 (4c4t) and a 290x used to hit 144fps stable no problems, what info would you need to help there?
iommu.txt
Edited by helin0x
