July 7, 20197 yr I will appreciate any help. I have watched all of Space Invade one videos, also watched Wendell L1 and others. I'm Stuck. I can not get Nvidia 1080 SC to pass through windows 10 vm I'm attaching a few text files of my system info, vm logs, xml , system log and IOMMU grouping some changes I added today after some web searches. append vfio-pci.ids=10de:1b80,10de:10f0 pcie_aspm=off initrd=/bzroot Thank you! system info.rtf system log.rtf win10-xml.rtf Log - Window 10 VM.rtf iommu grouping.rtf Edited July 7, 20197 yr by lamuerte
July 8, 20197 yr You're probably going to have to downgrade your BIOS. I had to revert to a January BIOS—basically, anything that predates the note "- Support new upcoming AMD cpu." should work. No amount of settings tweaks to the VM will solve it. https://www.reddit.com/r/Amd/comments/bh3qqz/agesa_0072_pci_quirk/
