July 12, 20197 yr Sorry more questions s post migration to 6.7.2 I've recently moved from 5.0.6, when I first booted my plus key failed the registration and i didn't have enough slots for all my disks to be added to the array. I've added the new plus key and gone to add the other drives but my last data drive is saying will be erased once array is started. I've read a post advising to go to Tools/New Config, select all assignments. Do I just start the array from this point now? Cheers in advance, Phil NB, Parity now showing same message so I'm guessing parity will be re built from data on all drives? Sorry still working out new version and dont want to loose any data where possible. Edited July 12, 20197 yr by Rodahle
July 12, 20197 yr Community Expert 8 minutes ago, Rodahle said: Do I just start the array from this point now? Yes. 8 minutes ago, Rodahle said: NB, Parity now showing same message so I'm guessing parity will be re built from data on all drives? Correct
