July 31, 20197 yr Hi. Just added an 4tb new drive to my computer and changed the computer case (using all the same hardware like before) And now its just spamming me down with "irq 16: nobody cared found on your server" My windows 10 VM feels like 2 fps even with nvidia card passthru. What can be the problem? I have attached the diagnostic file, still trying to understand the logg. sobihob-diagnostics-20190731-2328.zip Edited August 1, 20197 yr by Iminzilion
July 31, 20197 yr Community Expert Have you done a memtest? Why are you ignoring the other Fix Common Problems? They are easily fixed and you shouldn't ignore them unless you have a good explanation why they don't apply to you.
July 31, 20197 yr Author Do I have an good explenation? no, they was ignored before this problem happend (Yes I know stuff like that can´t be ruled out. Will fix them after this. Also added my lspci, looks like nvme is running on irq 16 (using that one for VM thats stuttering) lspci Edited July 31, 20197 yr by Iminzilion
August 1, 20197 yr Author It´s fixed!! After looking on lspci list I did: - Reinstalled GPU. - Disabled sound card in bios (didn´t need it anyway) - Wiggled around the memory stick. - reinstalled all power cable inside and changed on all the usb cables. Now vm has 100% speed and no more irq 16 problem. Then it´s time to fix my "ignored" list. Have spent many hours googling this, not easy when its irq Edit: @trurl Thanks for pushing me, I have now set my unassigned mounted drives as slave on my 2 dock that was error :P Edited August 1, 20197 yr by Iminzilion
