Need help with current configuration of unraid.
I am totally noob in building any kind of unraid servers.
Any help will be appreciated.
The server will only be used for home use. Backing up pictures and gopro footage.
My current planned configuration:
MotherboardMSI Pro Series Intel B250 LGA 1151
CPU: Intel Celeron g3930
RAM: Hynix 4GB PC3-12800 DDR3-1600MHz
Power supply: Zebronics 450W
HDD: Segate ironwolf 4tbx2
Thank you.
Does those ironwolf was empty ?
You should install Unraid with proper USB stick and well try before put in live. You also need consider use or not use parity disk to provide realtime disk protection ( not file protection ) or some backup plan.
Yes those iron wolf drive will be empty.
I'll adding another drive for parity.
What my main concern is that will this setup be okay for unraid.
Another question is what is unraid and lime tech unraid. I am Confused. Sorry for stupid question 😁
Thank you
Edited by Anurag Tiwari
May be could help
That is why we took the time, effort, and resources to ditch the old "Lime Technology" site and embrace Unraid.net as our new platform.
21 minutes ago, Benson said:
May be could help
Thank you. This cleared my doubt regarding unraid.
Previous question remains. Will this overall setup work or do i need to change anything?
This no problem for simple storage purpose.
Ok thank you for help.
Appreciated.
