need help with unRAID-Web
I loaded unRAID-Web using the unMENU package manager. It says unraidweb-0.1.04-i386-bubba.tgz.
/boot/unmenu/29-unmenu-sysinfo.awk is present.
I'm clicking on the SysInfo button on the left side under Extensions Menu. Then I select any of the dropdown menu items and get 404 - Not Found in the frame below.
The unmenu file "29-unmenu-sysinfo.awk" has absolutely nothing to do with the SysInfo extension built into unRAID-web.
"29-unmenu-sysinfo.awk" is used if you use the unMENU extension and then click on its System Info page.
