Sound Problems in macOS vm - Display-port Audio VEGA FE
I'm new at this, I succsfully able to bassthrought MY Vega FE card to macOS mojave 10.14.6, and I made sound working by pass-through the video device as multi functional and add the audio device as sub-function on the same bus/slot as showing here to work with macOS-vm:
      <driver name='vfio'/>
      <source>
        <address domain='0x0000' bus='0x84' slot='0x00' function='0x0'/>
      </source>
      <address type='pci' domain='0x0000' bus='0x04' slot='0x00' function='0x0' multifunction='on'/>
    </hostdev>
      <source>
        <address domain='0x0000' bus='0x84' slot='0x00' function='0x1'/>
      </source>
      <address type='pci' domain='0x0000' bus='0x04' slot='0x00' function='0x1' multifunction='on'/>
    </hostdev>
Now when I play music through display-port and even system sounds I get random micro cuts in the audio, static noises.
I searched about this I think it's the MSI problem, but how I can fix this with macOS vm.
Here's my XML for my VM:
<domain type='kvm' xmlns:qemu='http://libvirt.org/schemas/domain/qemu/1.0'>
  <name>Mojave</name>
  <uuid>e0bc5542-b1c5-9ea4-19d6-afb126fd7de1</uuid>
  <metadata>
    <vmtemplate xmlns="unraid" name="Linux" icon="unraid.png" os="linux"/>
  </metadata>
  <memory unit='KiB'>8388608</memory>
  <currentMemory unit='KiB'>8388608</currentMemory>
  <memoryBacking>
    <nosharepages/>
  </memoryBacking>
  <vcpu placement='static'>52</vcpu>
  <cputune>
    <vcpupin vcpu='0' cpuset='2'/>
    <vcpupin vcpu='1' cpuset='30'/>
    <vcpupin vcpu='2' cpuset='3'/>
    <vcpupin vcpu='3' cpuset='31'/>
    <vcpupin vcpu='4' cpuset='4'/>
    <vcpupin vcpu='5' cpuset='32'/>
    <vcpupin vcpu='6' cpuset='5'/>
    <vcpupin vcpu='7' cpuset='33'/>
    <vcpupin vcpu='8' cpuset='6'/>
    <vcpupin vcpu='9' cpuset='34'/>
    <vcpupin vcpu='10' cpuset='7'/>
    <vcpupin vcpu='11' cpuset='35'/>
    <vcpupin vcpu='12' cpuset='8'/>
    <vcpupin vcpu='13' cpuset='36'/>
    <vcpupin vcpu='14' cpuset='9'/>
    <vcpupin vcpu='15' cpuset='37'/>
    <vcpupin vcpu='16' cpuset='10'/>
    <vcpupin vcpu='17' cpuset='38'/>
    <vcpupin vcpu='18' cpuset='11'/>
    <vcpupin vcpu='19' cpuset='39'/>
    <vcpupin vcpu='20' cpuset='12'/>
    <vcpupin vcpu='21' cpuset='40'/>
    <vcpupin vcpu='22' cpuset='13'/>
    <vcpupin vcpu='23' cpuset='41'/>
    <vcpupin vcpu='24' cpuset='14'/>
    <vcpupin vcpu='25' cpuset='42'/>
    <vcpupin vcpu='26' cpuset='15'/>
    <vcpupin vcpu='27' cpuset='43'/>
    <vcpupin vcpu='28' cpuset='16'/>
    <vcpupin vcpu='29' cpuset='44'/>
    <vcpupin vcpu='30' cpuset='17'/>
    <vcpupin vcpu='31' cpuset='45'/>
    <vcpupin vcpu='32' cpuset='18'/>
    <vcpupin vcpu='33' cpuset='46'/>
    <vcpupin vcpu='34' cpuset='19'/>
    <vcpupin vcpu='35' cpuset='47'/>
    <vcpupin vcpu='36' cpuset='20'/>
    <vcpupin vcpu='37' cpuset='48'/>
    <vcpupin vcpu='38' cpuset='21'/>
    <vcpupin vcpu='39' cpuset='49'/>
    <vcpupin vcpu='40' cpuset='22'/>
    <vcpupin vcpu='41' cpuset='50'/>
    <vcpupin vcpu='42' cpuset='23'/>
    <vcpupin vcpu='43' cpuset='51'/>
    <vcpupin vcpu='44' cpuset='24'/>
    <vcpupin vcpu='45' cpuset='52'/>
    <vcpupin vcpu='46' cpuset='25'/>
    <vcpupin vcpu='47' cpuset='53'/>
    <vcpupin vcpu='48' cpuset='26'/>
    <vcpupin vcpu='49' cpuset='54'/>
    <vcpupin vcpu='50' cpuset='27'/>
    <vcpupin vcpu='51' cpuset='55'/>
  </cputune>
  <os>
    <type arch='x86_64' machine='pc-q35-3.1'>hvm</type>
    <nvram>/etc/libvirt/qemu/nvram/e0bc5542-b1c5-9ea4-19d6-afb126fd7de1_VARS-pure-efi.fd</nvram>
  </os>
  <features>
    <acpi/>
    <apic/>
  </features>
  <cpu mode='host-passthrough' check='none'/>
  <clock offset='utc'>
    <timer name='rtc' tickpolicy='catchup'/>
    <timer name='pit' tickpolicy='delay'/>
  </clock>
  <on_crash>restart</on_crash>
  <devices>
      <source file='/mnt/user/domains/Mojave/vdisk3.img'/>
      <target dev='hdc' bus='sata'/>
      <boot order='1'/>
      <address type='drive' controller='0' bus='0' target='0' unit='2'/>
    </disk>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x1f' function='0x2'/>
    </controller>
    <controller type='pci' index='0' model='pcie-root'/>
    <controller type='pci' index='1' model='pcie-root-port'>
      <model name='pcie-root-port'/>
      <target chassis='1' port='0x10'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x0' multifunction='on'/>
    </controller>
    <controller type='pci' index='2' model='pcie-root-port'>
      <target chassis='2' port='0x11'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x1'/>
    </controller>
    <controller type='pci' index='3' model='pcie-root-port'>
      <target chassis='3' port='0x12'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x2'/>
    </controller>
    <controller type='pci' index='4' model='pcie-root-port'>
      <target chassis='4' port='0x13'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x3'/>
    </controller>
    <controller type='pci' index='5' model='pcie-root-port'>
      <target chassis='5' port='0x8'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x0'/>
    </controller>
      <address type='pci' domain='0x0000' bus='0x02' slot='0x00' function='0x0'/>
    </controller>
    </controller>
      <master startport='0'/>
    </controller>
      <master startport='2'/>
    </controller>
      <master startport='4'/>
    </controller>
    <interface type='bridge'>
      <mac address='52:54:00:80:db:ed'/>
      <source bridge='br0'/>
      <model type='vmxnet3'/>
      <address type='pci' domain='0x0000' bus='0x01' slot='0x00' function='0x0'/>
    </interface>
    <serial type='pty'>
        <model name='isa-serial'/>
      </target>
    </serial>
    <console type='pty'>
    </console>
    <channel type='unix'>
    </channel>
      <address type='usb' bus='0' port='3'/>
    </input>
      <source>
      </source>
    </hostdev>
      <source>
      </source>
    </hostdev>
    <hostdev mode='subsystem' type='usb' managed='no'>
      <source>
        <vendor id='0x05ac'/>
        <product id='0x026c'/>
      </source>
    </hostdev>
      <source>
        <product id='0x8289'/>
      </source>
      <address type='usb' bus='0' port='2'/>
    </hostdev>
      <source>
        <vendor id='0x1bcf'/>
        <product id='0x0824'/>
      </source>
      <address type='usb' bus='0' port='4'/>
    </hostdev>
    <memballoon model='none'/>
  </devices>
  <qemu:commandline>
    <qemu:arg value='-usb'/>
    <qemu:arg value='-device'/>
    <qemu:arg value='usb-mouse,bus=usb-bus.0'/>
    <qemu:arg value='usb-kbd,bus=usb-bus.0'/>
    <qemu:arg value='isa-applesmc,osk=,<REDACTED>'/>
    <qemu:arg value='-smbios'/>
    <qemu:arg value='type=2'/>
    <qemu:arg value='-cpu'/>
    <qemu:arg value='Penryn,vendor=GenuineIntel,kvm=on,+fpu,+vme,+de,+pse,+tsc,+msr,+pae,+mce,+cx8,+apic,+sep,+mtrr,+pge,+mca,+cmov,+pat,+pse36,+clflush,+acpi,+mmx,+fxsr,+sse,+sse2,+ss,+ht,+tm,+pbe,+syscall,+nx,+pdpe1gb,+rdtscp,+lm,+tsc,+pni,+pclmulqdq,+dtes64,+monitor,+ds_cpl,+vmx,+smx,+est,+tm2,+ssse3,+fma,+cx16,+xtpr,+pdcm,+pcid,+dca,+sse4_1,+sse4_2,+x2apic,+movbe,+popcnt,+aes,+xsave,+avx,+f16c,+rdrand,+lahf_lm,+abm,+3dnowprefetch,+fsgsbase,+tsc_adjust,+bmi1,+hle,+avx2,+smep,+bmi2,+erms,+invpcid,+rtm,+rdseed,+adx,+smap,+xsaveopt,+arat,vmware-cpuid-freq=on,'/>
</qemu:commandline>
</domain>
Edited by trurl
redact osk
