Help with hardware errors reported by Fix Common Problems
So I got an error from Fix Common Problems that boils down to, "Something is wrong, you should look into that. Maybe the forum will help you." So I was hoping someone might know what I should be looking for.unraid-green-diagnostics-20190929-1957.zip
Sep 29 08:17:21 unraid-green kernel: mce: [Hardware Error]: Machine check events logged
Sep 29 08:17:21 unraid-green kernel: EDAC sbridge MC0: HANDLING MCE MEMORY ERROR
Sep 29 08:17:21 unraid-green kernel: EDAC sbridge MC0: CPU 0: Machine Check Event: 0 Bank 7: 8c00004000010092
Sep 29 08:17:21 unraid-green kernel: EDAC sbridge MC0: TSC 2c0d42b11d812
Sep 29 08:17:21 unraid-green kernel: EDAC sbridge MC0: ADDR 103a25a900
Sep 29 08:17:21 unraid-green kernel: EDAC sbridge MC0: MISC 440403486
Sep 29 08:17:21 unraid-green kernel: EDAC sbridge MC0: PROCESSOR 0:306e4 TIME 1569770241 SOCKET 0 APIC 0
Sep 29 08:17:21 unraid-green kernel: EDAC MC0: 1 CE memory read error on CPU_SrcID#0_Ha#0_Chan#0_DIMM#1 (channel:0 slot:1 page:0x103a25a offset:0x900 grain:32 syndrome:0x0 -  area:DRAM err_code:0001:0092 socket:0 ha:0 channel_mask:1 rank:5)
Bad RAM
Thanks. I have ECC memory and my understanding is that those where recoverable errors. Any thoughts on how worried I should be. For some background I just ran memtest86+ for about 50 hours earlier this week and it didn't return any errors.
Because the errors were being corrected
Reason why you have ECC memory is so that the system will catch those errors and alert you so that you can replace the memory sticks.
Makes sense. Thanks again for your help.
