October 3, 20197 yr I've been messing with this for quite a while (or several hours atleast)...it seems that unraid's config page for the UPS is focused on USB attached devices. However I wanted to shutdown my UPS when using the Network Management Card and not USB. 1) Set the option 'Turn off UPS after shutdown' to 'No'. This only works when using a direct attached ups with usb or maybe serial. 2) Add the command "sed -i 's/\/sbin\/apcupsd/\/sbin\/apcupsd -p/g' /etc/rc.d/rc.apcupsd" to your go file "/boot/config/go". 3) reboot This will start "/sbin/apcupsd" with the -p flag (aka --kill-on-powerfail), this will instruct the ups to shutdown before the system is given the shutdown command. Since most SmartUPS's can have a shutdown delay set, this isn't a problem. Because the command is sent before shutting down the system, the network is still up and the ups is able to receive the request. Setting 'Turn off UPS after shutdown' to 'Yes', would execute "/etc/apcupsd/apccontrol killpower" at the very end of the shutdown sequence when the network is already down. Maybe there's some room for improvement here in how unraid handles this/does the config? Edited October 3, 20197 yr by hotio
June 1, 20206 yr On 10/3/2019 at 11:48 PM, hotio said: I've been messing with this for quite a while (or several hours atleast)...it seems that unraid's config page for the UPS is focused on USB attached devices. However I wanted to shutdown my UPS when using the Network Management Card and not USB... Oh God, thank you. I've been looking on and off over the years for a fix to this. After looking for and testing different things for a lot of that time, I finally made a topic back in mid 2019, but no one had a fix (let alone a reply): I gave your fix a go, and it worked perfectly after a quick test last night. The UPS goes into sleep mode (LEDs cycling) once the shutdown delay has done its thing. I can even see the UPS logs reporting that the unRAID server has issued the PowerChute shutdown command - I don't recall ever seeing that before. Checking the IPMI interface during the shutdown process doesn't throw any apcupsd errors anymore (the ones you see in the screenshot of that thread). Before doing your fix, the UPS would just run its batteries right down to critical, causing unnecessary wear on them when I wanted it to shutdown around the 80% remaining mark. Thank you for this.
June 1, 20206 yr Author Glad to see it helped somebody...it also took me a while before I found the solution....never thought limetech wouldn't have thought about this usecase, although on ubuntu I also had to override the default systemd service. You'd expect an UI toggle to include all use cases and not just usb....
June 2, 20206 yr Annoyingly, it actually did work at some point in an older build of unRAID - something must have been changed regarding apcupsd. I wouldn't be able to tell you which one build, but I do recall seeing my UPS going into sleep correctly once back in late 2018.
April 12, 20242 yr Hi! I'm fighting with a similar issue. I can get my APC Smart-UPS 1500 with NMC3 to communicate with my Unraid server, and the server shutdown on specific battery level or time on battery works. However, I cannot get it to properly issue a UPS shutdown command. I've attempted the above fix with both PCnet and SNMP drivers in Unraid. The SNMP community on my UPS is configured for Write+. Both outlet groups on the UPS are configured for a 300 second power-off delay. My server's IP is configured as a PowerChute client. Watching the logs on my server, I see this during a UPS-triggered shutdown: I'm not sure if the last line in the log is related to the second to last line in the log. In either case, the UPS does not shut down after the pause. My next stop is NUT, but I would stubbornly prefer to manage this all within Unraid "natively" if I can.
