Jump to content
Marc_G2
Wake on LAN not Working (Realtek LAN Controller)
8 posts in this topic Last Reply
Posted (edited)
I've been struggling to get Wake on LAN for a few days now.  Does anyone have any ideas?
One potential issue I noticed is how I'm not getting any LED activity with the ethernet port while the system is asleep.  I talked to a MSI rep and he had no idea if that was normal behavior or not.
Summary:
1) MOBO: MSI X470 Gaming Plus
2) Router is Netgear R6400
3) BIOS ErP set to Disabled
4) BIOS PCIe and USB Wake functions Enabled
5) unRAID 6.7.2
6) S3 Sleep, using S3 Sleep plugin along with the information here http://lime-technology.com/wiki/index.php?title=Setup_Sleep_(S3)_and_Wake_on_Lan_(WOL)
7) I've been using this utility to send the wake packet: https://www.depicus.com/wake-on-lan/wake-on-lan-cmd
8 ) Wake from USB does work
Running ethtool eth0 yields this
Settings for eth0:
        Supported ports: [ TP AUI BNC MII FIBRE ]
        Supported link modes:   10baseT/Half 10baseT/Full
                                100baseT/Half 100baseT/Full
                                1000baseT/Full
        Supported pause frame use: Symmetric Receive-only
        Supports auto-negotiation: Yes
        Supported FEC modes: Not reported
        Advertised link modes:  10baseT/Half 10baseT/Full
                                1000baseT/Full
        Advertised pause frame use: Symmetric Receive-only
        Advertised auto-negotiation: Yes
        Advertised FEC modes: Not reported
        Link partner advertised link modes:  10baseT/Half 10baseT/Full
                                             1000baseT/Half 1000baseT/Full
        Link partner advertised pause frame use: Symmetric Receive-only
        Link partner advertised auto-negotiation: Yes
        Link partner advertised FEC modes: Not reported
        Speed: 1000Mb/s
        Duplex: Full
        Port: MII
        PHYAD: 0
        Transceiver: internal
        Auto-negotiation: on
        Supports Wake-on: pumbg
        Wake-on: g
        Current message level: 0x00000033 (51)
                               drv probe ifdown ifup
        Link detected: yes
Edited by Marc_G2
Share this post
Link to post
MSI X470 Gaming Plus - Realtek® 8111H , WOL won't work under Unraid or some Linux platform.
Share this post
Link to post
Thanks for the recommendation.   I will buy that if nothing else works.  I found some other potential solutions which I'll try first.
Share this post
Link to post
Well I confirmed that I can get WOL working on Windows, but still can't get it working with unRAID.  Is it a driver issue?  I couldn't find any information confirming that my Realtek Chipset was known to not work.  Where should I be looking for that kind of information?
Share this post
Link to post
I would also be checking BIOS settings to see if there are any options about WOL.  See if the REaltek NIC has any BIOS options.
Share this post
Link to post
I have confirmed my BIOS settings are good.  WOL is lumped into the wake by pcie device setting.  I also disabled Erp for good measure
Share this post
Link to post
  Only 75 emoji are allowed.
