[Solved] Added 2 WD drives and unRAID went bonkers! (due to 3.3v SATA power issue)
Hi there, I added two WD 8TB drives to a perfectly working unRAID system - when the system boots up, it goes into Stale Configuration.
I have attached the diagnostic file here, generated when the system could not gracefully shut down after 60 secs. Further to this one of my new 8TB became disabled. (Disk 7)
Any advice will be greatly appreciated. Regards. cL
clnasty-diagnostics-20191119-2208.zip
Edited by cliewmc
minor correction
And it gets worse, the unRAID comes up on the attached monitor but GUI does not connect, and after about 5 mins, it comes up. Then it says 'starting services' for a long time... when I click on the log, it says "waiting for 192.168.0.11..."
There's a problem with one of them since early booting :
Nov 19 22:03:25 cLNASty kernel: sd 6:0:11:0: [sdn] tag#0 UNKNOWN(0x2003) Result: hostbyte=0x0b driverbyte=0x00
Nov 19 22:03:25 cLNASty kernel: sd 6:0:11:0: [sdn] tag#0 CDB: opcode=0x88 88 00 00 00 00 03 a3 81 2a a8 00 00 00 08 00 00
Nov 19 22:03:25 cLNASty kernel: print_req_error: I/O error, dev sdn, sector 15628053160
Nov 19 22:03:25 cLNASty kernel: sd 6:0:11:0: [sdn] tag#1 UNKNOWN(0x2003) Result: hostbyte=0x00 driverbyte=0x08
Nov 19 22:03:25 cLNASty kernel: sd 6:0:11:0: [sdn] tag#1 Sense Key : 0x2 [current]
Nov 19 22:03:25 cLNASty kernel: sd 6:0:11:0: [sdn] tag#1 ASC=0x4 ASCQ=0x0
Nov 19 22:03:25 cLNASty kernel: sd 6:0:11:0: [sdn] tag#1 CDB: opcode=0x88 88 00 00 00 00 03 a3 81 2a a8 00 00 00 08 00 00
Check connections, there's not even a valid SMART report.
Thanks johnnie, I suspect I may have damaged the SATA connector on the drive when I was dismantling it from the external casing. I am removing both the drives to test now.
So on reboot, it goes back to normal but Disk 7 remains disabled. Any way to bring it back to 'life'?
thanks johnnie for your assistance. i can never say that enough.
Edited by cliewmc
minor edit
I have put the disk config in maintenance mode, and running an xfs_repair check now with -n to see what comes up.
Once a disk gets disable it remains so until rebuilt, make sure emulated disk is mounting correctly before rebuilding on top.
Thanks, I had to stop the array, assign No Device to Disk 7, then start the service, stop, assign the same disk to it, restart... to get the data-rebuild going.
I wonder what I can do with the 2 new WD drives? Any ideas? One gave the errors, and the other was not detected at all in Unassigned Devices... I think I will try adding on the missing one again after my unRAID gets back to a stable state.
My plan was to install an extra parity and add another 8TB to the array... I will have to wait for a day or two until the rebuild is complete.
Hi Frank1940, thanks! The response was extremely useful - especially since I may ignorantly end up with two bricks! Out of warranty, may I add. Cheers.
My friend told me to plug the troublesome drives (with the 3.3V pin issues) into my hotswap cages - lo & behold I was able to 'see' them. I am now preclearing all in one go! It seems that the hotswap cages corrects the power issues. I am really grateful for my peer expertise including you guys. My unRAID is hopefully on its way to a 'healthy' state. Thank you all.
