Gigabyte X570 AORUS Elite / Pro (WiFi) / Ultra Tips & Tricks
1 hour ago, Dava2k7 said:
No but it didn’t do anything inside vm do I need the vfio config file in place before doing this? Or Somin?
You need to actually read the first post in this thread. You need to make sure your unraid usb is on the 0b:00.3 USB controller, and the occulus stuff is NOT on that controller. Then you need to pass through 06:00.0, 06:00.1, and 06:00.3. This can all be done very easily with the vfio-pci config plugin. Do not attempt to do anything else until you understand what you are doing.
  • Replies 149
  • Views 90.9k
  • Here they are with F10 bios and above settings. The Fresco Logic FL1100 is a PCIe card.
  • The fun never stops, I uploaded a new 6.8.0-rc5 kernel today that incorporates a bunch of goodies for this board. Brand new k10temp patches for Ryzen, and a fix for passing through onboard audio!
  • Note that I can not pass the on board audio even though it's in it's own group. I've always used a (USB) Astro Mixamp so it's no loss to me.
@Skitals In your first post can you mention setting CSM to enable and booting via legacy rather that UEFI? I had major problems passing through a GPU until I enabled that and checked unraid to make sure I was in legacy mode and then everything worked.
I am all UEFI, no legacy. It might come down to your GPU and which mode(s) it supports, if you are talking about an older card.
I have a new RX5700XT and it would not work with UEFI enabled on the BIOS. It was also the same for my GTX 960.
Upgraded my old 6700k system to the X570 Aorus Master. Everything working pretty good even added a 4 x nvme card I had sitting here and working well.
Only thing I would like to do is pass temps through to Telegrah for Grafana any ideas ??
I just got the 3900x and x570 pro running, i'm only able to get one temperature reading to show up, any ideas?
I seem to be getting my temps and fan speeds ok.
I know its for a server but would have been nice to be able to change the board rgb in the bios.
Version 6.8.2
651482465_ScreenShot2020-02-25at11_18_05PM.thumb.png.d096e9f687509a0972560d7d22e2de17.png
Edited by JaseNZ
Has anyone had issues with using both nvme slots for their cache? When I use either one separately the cache works but once I try to use both at once I get IO errors.
Sorry I am using 2 x 1 TB SSD's for my cache with zero issues.
I am using a Asus tuf x570-plus motherboard but the IOMMU-groups seams to be identical. After reading the whole thread I have placed the unraid usb on
the 0b:00.3 USB controller. I have also passed 06:00.1, and 06:00.3 controllers using the VIFO-PCI plugin.
My Windows 10 VM is using 06:00.1 and it works perfectly. But I have not got my other VM's to be able to use the 06:00.3 controller as nothing happens when I plug anything in the ports. I am not sure which ports is connected to 06:00.3 but I have tried all ports on my unraid server.
Or is it connected to the single USB-C connector ?
Do I also need to pass through:
Group 26 06:00.0 1022:1485 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
Edit: passing through Group 26 did not change anything. When looking in the log for the other VM I get this:
2020-03-11T16:02:11.664422Z qemu-system-x86_64: vfio: Cannot reset device 0000:06:00.0, depends on group 27 which is not owned.
Edited by Cliff
Hi all i have same problem with 3900x and MSI B450 tomahawk max
now i have 2 gpu card (i want 1 vm use 1 gpu card ,GTX660 and GTX650)
i try edit video=efifb:off and watch Spaceinvader One "How to passthrough an nvidia gpu as primary gpu in unRAID"
to enter command to use dump file but still can't use gpu card
now i should try which part to use the gpu card.....thank you all
Sorry my bad english....
Are those GPUs uefi compatible? If not good luck passing them through, probably won't work.
How to check GPUs uefi compatible? i think is compatible because i use GTX650 can passthrough with old computer
this is my PCI Devices and IOMMU Groups
IOMMU group 0:[1022:1482] 00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 1:[1022:1483] 00:01.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge
IOMMU group 2:[1022:1482] 00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 3:[1022:1482] 00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 4:[1022:1483] 00:03.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge
IOMMU group 5:[1022:1482] 00:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 6:[1022:1482] 00:05.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 7:[1022:1482] 00:07.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 8:[1022:1484] 00:07.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
IOMMU group 9:[1022:1482] 00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
IOMMU group 10:[1022:1484] 00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
IOMMU group 11:[1022:1484] 00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
IOMMU group 12:[1022:1484] 00:08.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
IOMMU group 13:[1022:790b] 00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 61)
[1022:790e] 00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
IOMMU group 14:[1022:1440] 00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 0
[1022:1441] 00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 1
[1022:1442] 00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 2
[1022:1443] 00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 3
[1022:1444] 00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 4
[1022:1445] 00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 5
[1022:1446] 00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 6
[1022:1447] 00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 7
IOMMU group 15:[1022:43d5] 03:00.0 USB controller: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset USB 3.1 XHCI Controller (rev 01)
IOMMU group 16:[1022:43c8] 03:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset SATA Controller (rev 01)
IOMMU group 17:[1022:43c6] 03:00.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Bridge (rev 01)
IOMMU group 18:[1022:43c7] 20:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port (rev 01)
IOMMU group 19:[1022:43c7] 20:01.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port (rev 01)
IOMMU group 20:[1022:43c7] 20:04.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 400 Series Chipset PCIe Port (rev 01)
IOMMU group 21:[10ec:8168] 22:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
IOMMU group 22:[10de:0fc6] 25:00.0 VGA compatible controller: NVIDIA Corporation GK107 [GeForce GTX 650] (rev a1)
IOMMU group 23:[10de:0e1b] 25:00.1 Audio device: NVIDIA Corporation GK107 HDMI Audio Controller (rev a1)
IOMMU group 24:[10de:11c0] 26:00.0 VGA compatible controller: NVIDIA Corporation GK106 [GeForce GTX 660] (rev a1)
IOMMU group 25:[10de:0e0b] 26:00.1 Audio device: NVIDIA Corporation GK106 HDMI Audio Controller (rev a1)
IOMMU group 26:[1022:148a] 27:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
IOMMU group 27:[1022:1485] 28:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
IOMMU group 28:[1022:1486] 28:00.1 Encryption controller: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP
IOMMU group 29:[1022:149c] 28:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller
IOMMU group 30:[1022:1487] 28:00.4 Audio device: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller
IOMMU group 31:[1022:7901] 30:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51)
IOMMU group 32:[1022:7901] 31:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51)
this is my vm xml
<domain type='kvm'>
  <name>Windows 10</name>
  <uuid>d2d767e0-926c-26df-82d7-a49f70260e5c</uuid>
  <metadata>
  </metadata>
  <memory unit='KiB'>4194304</memory>
  <currentMemory unit='KiB'>4194304</currentMemory>
  <memoryBacking>
    <nosharepages/>
  </memoryBacking>
  <vcpu placement='static'>4</vcpu>
  <cputune>
    <vcpupin vcpu='0' cpuset='0'/>
    <vcpupin vcpu='1' cpuset='1'/>
    <vcpupin vcpu='2' cpuset='2'/>
    <vcpupin vcpu='3' cpuset='3'/>
  </cputune>
  <os>
    <type arch='x86_64' machine='pc-q35-4.2'>hvm</type>
    <nvram>/etc/libvirt/qemu/nvram/d2d767e0-926c-26df-82d7-a49f70260e5c_VARS-pure-efi.fd</nvram>
  </os>
  <features>
    <acpi/>
    <apic/>
    <hyperv>
      <relaxed state='on'/>
      <vapic state='on'/>
    </hyperv>
  </features>
  <cpu mode='host-passthrough' check='none'>
    <topology sockets='1' cores='2' threads='2'/>
    <cache mode='passthrough'/>
    <feature policy='require' name='topoext'/>
  </cpu>
  <clock offset='localtime'>
  </clock>
  <on_crash>restart</on_crash>
  <devices>
      <source file='/mnt/user/isos/Windows 10 + Office 2019 20200201.iso'/>
      <target dev='hda' bus='sata'/>
      <readonly/>
      <boot order='2'/>
    </disk>
      <source file='/mnt/user/isos/virtio-win-0.1.173.iso'/>
      <target dev='hdb' bus='sata'/>
      <readonly/>
    </disk>
      <driver name='qemu' type='qcow2' cache='writeback'/>
      <source file='/mnt/user/domains/Windows 10/vdisk1.img'/>
      <target dev='hdc' bus='sata'/>
      <boot order='1'/>
      <address type='drive' controller='0' bus='0' target='0' unit='2'/>
    </disk>
    <controller type='pci' index='0' model='pcie-root'/>
    <controller type='pci' index='1' model='pcie-root-port'>
      <model name='pcie-root-port'/>
      <target chassis='1' port='0x8'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x0' multifunction='on'/>
    </controller>
    <controller type='pci' index='2' model='pcie-root-port'>
      <target chassis='2' port='0x9'/>
    </controller>
    <controller type='pci' index='3' model='pcie-root-port'>
      <target chassis='3' port='0xa'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x2'/>
    </controller>
    <controller type='pci' index='4' model='pcie-root-port'>
      <target chassis='4' port='0x13'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x3'/>
    </controller>
    <controller type='pci' index='5' model='pcie-root-port'>
      <target chassis='5' port='0x14'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x4'/>
    </controller>
    <controller type='pci' index='6' model='pcie-root-port'>
      <target chassis='6' port='0xb'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x3'/>
    </controller>
    <controller type='pci' index='7' model='pcie-to-pci-bridge'>
      <model name='pcie-pci-bridge'/>
      <address type='pci' domain='0x0000' bus='0x01' slot='0x00' function='0x0'/>
    </controller>
      <address type='pci' domain='0x0000' bus='0x02' slot='0x00' function='0x0'/>
    </controller>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x1f' function='0x2'/>
    </controller>
    </controller>
      <master startport='0'/>
    </controller>
      <master startport='2'/>
    </controller>
      <master startport='4'/>
    </controller>
    <interface type='bridge'>
      <mac address='52:54:00:a2:1f:63'/>
      <source bridge='br0'/>
      <model type='virtio'/>
      <address type='pci' domain='0x0000' bus='0x03' slot='0x00' function='0x0'/>
    </interface>
    <serial type='pty'>
        <model name='isa-serial'/>
      </target>
    </serial>
    <console type='pty'>
    </console>
    <channel type='unix'>
    </channel>
    </input>
      <driver name='vfio'/>
      <source>
        <address domain='0x0000' bus='0x26' slot='0x00' function='0x0'/>
      </source>
      <rom file='/mnt/user/appdata/GTX660.dump'/>
      <address type='pci' domain='0x0000' bus='0x04' slot='0x00' function='0x0'/>
    </hostdev>
    <memballoon model='none'/>
  </devices>
</domain>
My system info
Model: Custom
M/B: Micro-Star International Co., Ltd B450 TOMAHAWK MAX (MS-7C02) Version 1.0 - s/n: JC16755566
BIOS: American Megatrends Inc. Version 3.50. Dated: 11/07/2019
CPU: AMD Ryzen 9 3900X 12-Core @ 3800 MHz
HVM: Enabled
IOMMU: Enabled
Cache: 768 KiB, 6144 KiB, 65536 KiB
Memory: 32 GiB DDR4 (max. installable capacity 128 GiB)
Network: bond0: fault-tolerance (active-backup), mtu 1500
 eth0: 1000 Mbps, full duplex, mtu 1500
Kernel: Linux 5.5.8-Unraid x86_64
OpenSSL: 1.1.1d
Thank you all
Any reason you did not passthrough the GPU video and sound component? All i see is the video part. Have you tried passing through both?
Same.....also can't passthrough the GPU now i use q35-4.2 is can't see GPU card just show is unknow hardware,
but i remember if use i440FX is can see the GPU Card but error 43
this problem i try 7 days......
Edited by eddy0616
Try to make a linux vm to see if its a windows issue. Try ubuntu or something...
Also make sure you windows iso is up to date,
Edited by david279
Edited 14 hours ago by david279
i try ubuntu is can show the video use to gpu card,it mean is my win10 problem ?
Go get you a legit copy of windows and try again. That windows 10 + Office iso that I see you using seem a bit odd. 🤔
now i use New Win10 to try it but also error 43....i try Q35 and i44FX....same problem....
my mb bios need change to use uefi boot up the unraid usb?
3 hours ago, eddy0616 said:
error 43.
Code 43 is a generic catch-all for a problem, and doesn't specifically refer to anything in particular.  Last time I had it was with a brand-new 1050.  RMA'd it for a different card and the replacement worked right out of the box.  Mind you, the original card did work correctly in a Windows box.
Another time, I was getting it, I got around it by simply installing the nVidia software manually instead of going through Windows Update to have it set up the driver.
Thank you you reply,i install a new win10 and find nVidia Software drives,but still same problem,my Win 10 now is use Q35,OVMF......
  • 2 months later...
Thanks for this information.
I have the same set up and also is working great, I have noticed though that When you try restart a vm it goes into a paused state and needs to be force stopped and restarted.
Logs show gpu related issue vfio_err_notifier_handler(0000:0a:00.1) Unrecoverable error detected
I have an Rx580 passed though.
Any help would be amazing.
Edited by steveBBB
Error
  • 2 months later...
On 12/18/2019 at 10:02 AM, Skitals said:
No experience with aida64, but here are my results (aida64 v6.20.5300)
Memory Read: 53295 MB/s
Memory Write: 44206 MB/s
Memory Copy: 51345 MB/s
Memory Latency: 87.4 ns
Edit: I had noticed high cpu usage while the guest report 1%, changing this from no to yes helped a bit and brough latency "down" to 83.3 ns. Still seems a bit high, yes?
Edit 2: Okay, I got memory latency "down" to 79.0ns AND reduced my idle cpu usage to practically 0% by making these two changes:
Switched the usb controller to 3.0 nec.
Turned hpet back OFF and added these hyperv flags:
Here are the new results:
Memory Read: 56165 MB/s
Memory Write: 44619 MB/s
Memory Copy: 52043 MB/s
Memory Latency: 79.0 ns
Hey!
I have a rather similar setup: 3900x, Gigabyte X570 Pro Wifi, 64GB Ram 3200MHz, RTX 2070Super & 1070ti.
I am passing through 10 Cores (leaving the first two across for Unraid) and both GPUs to a windows VM.
My performance is rather good but at time feels a bit sluggish (very hard to put into numbers). After Effects/Lightroom and some other Adobe software especially feels quite sluggish.
I ran AIDA in trial mode and got result like you in your first test. Tried to implement your hyperv flags but not sure if I have done it right.
I just added them into the XML under hyperv
<hyperv>
      <vapic state='on'/>
	  <vpindex state='on'/>
      <synic state='on'/>
      <stimer state='on'/>
    </hyperv>
Not sure If thats correct.
