Multi VM Multi monitor. Am I dreaming?
my current set up
3 workstations each running at least 3 monitors (often 5)  1 monitor unique to the system, the others through a 4xDVI KVM. those monitors are high res (2560x1440 or higher)
The unique monitor is used for a work list so that the user knows when to switch between systems.
Is there a software layer KVM that could enable this within unraid? the images must be lossless AND each system has to continue to think they have control of the monitors, the software we run gets mad if monitors "disappear" when you switch to the other systems.
A bonus would be if the mouse keyboards and other USB devices could also be emulated to the systems 'not in focus'. the Adder kvm we use does this for the mouse and keyboard.
Thank you for any suggestions.  this continues to be a support pipe dream of mine to reduce the hardware foot print, and cabling nightmare.
