Dynamix system temp, fan auto control - Won't detect drivers
Anything i can do?
See reddit post.
Is this a Kernel issue, Mobo issue, or Ryzen issue?
See below, how can i generate drivers.conf?
Added 'modprob nct6775 0xd352 to go file.
added sensors.conf to plugin folder
#sensors
chip "k10temp-pci-00c3"
    label temp1 "MB Temp"
    label temp2 "CPU Temp"
i ran sensors-detect and got
Trying family `VIA/Winbond/Nuvoton/Fintek'... Yes
Found unknown chip with ID 0xd352
Then ran "sensors"
and got:
modprobe nct6775 0xd352^C
and got
k10temp-pci-00c3
Adapter: PCI adapter
Tdie: +47.4°C (high = +70.0°C)
Tctl: +57.4°C
nct6795-isa-0a20
Adapter: ISA adapter
Vcore: +1.42 V (min = +0.00 V, max = +1.74 V)
in1: +1.02 V (min = +0.00 V, max = +0.00 V) ALARM
AVCC: +3.34 V (min = +0.00 V, max = +0.00 V) ALARM
+3.3V: +3.38 V (min = +0.00 V, max = +0.00 V) ALARM
in4: +1.01 V (min = +0.00 V, max = +0.00 V) ALARM
in5: +0.15 V (min = +0.00 V, max = +0.00 V) ALARM
in6: +0.74 V (min = +0.00 V, max = +0.00 V) ALARM
3VSB: +3.33 V (min = +0.00 V, max = +0.00 V) ALARM
Vbat: +3.25 V (min = +0.00 V, max = +0.00 V) ALARM
in9: +1.82 V (min = +0.00 V, max = +0.00 V) ALARM
in10: +0.00 V (min = +0.00 V, max = +0.00 V)
in11: +0.74 V (min = +0.00 V, max = +0.00 V) ALARM
in12: +1.16 V (min = +0.00 V, max = +0.00 V) ALARM
in13: +0.68 V (min = +0.00 V, max = +0.00 V) ALARM
in14: +1.51 V (min = +0.00 V, max = +0.00 V) ALARM
fan1: 0 RPM (min = 0 RPM)
fan2: 2428 RPM (min = 0 RPM)
fan3: 1165 RPM (min = 0 RPM)
fan4: 830 RPM (min = 0 RPM)
fan5: 836 RPM (min = 0 RPM)
fan6: 849 RPM (min = 0 RPM)
SYSTIN: +33.0°C (high = +0.0°C, hyst = +0.0°C) ALARM sensor = CPU diode
CPUTIN: +39.0°C (high = +110.0°C, hyst = +90.0°C) sensor = thermistor
AUXTIN0: +41.0°C (high = +110.0°C, hyst = +90.0°C) sensor = thermistor
AUXTIN1: -128.0°C sensor = thermistor
AUXTIN2: +40.0°C sensor = thermistor
AUXTIN3: -1.0°C sensor = thermistor
SMBUSMASTER 0: +57.5°C
PCH_CHIP_CPU_MAX_TEMP: +0.0°C
PCH_CHIP_TEMP: +0.0°C
PCH_CPU_TEMP: +0.0°C
intrusion0: ALARM
intrusion1: ALARM
beep_enable: disabled
You can go directly to the correct support thread for any of your plugins by selecting its Support link on the Plugins page in the webUI.
The support link redirects to
But there is no where to post?
Do you have a link to create support post?
Edited by mspencerl87
Locking this thread since the user has found the support thread.
  • trurl locked this topic
